Discuss
New Fridge not working
 in
Refrigerator & Freezer Repair
Hi there, We had a new fridge delivered and duly plugged it into the exisiting socket. It seemed to work
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » New Fridge not working
  #1 (permalink)
Old 09-24-2010, 08:31 AM
Junior Member
winxile is on a distinguished road
Question New Fridge not working
Model Number: LFTR1814L   Brand: Frigidaire   Age: Less than 1 year
Hi there,
We had a new fridge delivered and duly plugged it into the exisiting socket. It seemed to work for a day or so and then died. Now it is not working and the store is sending a replacement.
Friends have advised the the problem might have due to our electricity circuits and the compressor might have been damamged due to low voltage. Is this likely ? we were running a fridger for several years and the only other thing running from the sockets is a gas stove.
If it was a problem with the circuit, surely the circuit breaker would have tripped or there would be some other symptom from the fridge?
Is is likely that a new model would be affected ? Or is there some sort of reset within the unit itself?
Now we are worried that the new one will blow too when we plug it in...is there anyway to check beforehand?
Ads By Google
Related Models
Frigidaire LFTR1814LB0 REFRIGERATOR
Frigidaire LFTR1814LB1 REFRIGERATOR
Frigidaire LFTR1814LB2 REFRIGERATOR
Frigidaire LFTR1814LB3 REFRIGERATOR
Frigidaire LFTR1814LB4 REFRIGERATOR
Frigidaire LFTR1814LB6 REFRIGERATOR
Frigidaire LFTR1814LW0 REFRIGERATOR
Frigidaire LFTR1814LW1 REFRIGERATOR
Frigidaire LFTR1814LW2 REFRIGERATOR
Frigidaire LFTR1814LW3 REFRIGERATOR
Frigidaire LFTR1814LW4 REFRIGERATOR
Frigidaire LFTR1814LW5 REFRIGERATOR
Frigidaire LFTR1814LW6 REFRIGERATOR
 LFU480CE Air Conditioner
Frigidaire LFUH21F7LM0 FREEZER
Frigidaire LFUH21F7LM1 FREEZER
Frigidaire LFUH21F7LM2 FREEZER
Frigidaire LFUS2613LE0 REFRIGERATOR
Frigidaire LFUS2613LE1 REFRIGERATOR
Frigidaire LFUS2613LE2 REFRIGERATOR
Frigidaire LFUS2613LE3 REFRIGERATOR
Frigidaire LFUS2613LF0 REFRIGERATOR
Frigidaire LFUS2613LF1 REFRIGERATOR
Frigidaire LFUS2613LF2 REFRIGERATOR
Frigidaire LFUS2613LF3 REFRIGERATOR
Frigidaire LFUS2613LM0 REFRIGERATOR
Frigidaire LFUS2613LM1 REFRIGERATOR
Frigidaire LFUS2613LM2 REFRIGERATOR
Frigidaire LFUS2613LM3 REFRIGERATOR
Frigidaire LFUS2613LP0 REFRIGERATOR
Frigidaire LFUS2613LP1 REFRIGERATOR
Frigidaire LFUS2613LP2 REFRIGERATOR
Frigidaire LFUS2613LP3 REFRIGERATOR
Frigidaire LFW201EW0 WASHER
 LFX21960ST Refrigerator
 LFX21971ST Refrigerator
 LFX21975ST Refrigerator
 LFX21980ST Refrigerator
 LFX23961SB Refrigerator
 LFX23961ST Refrigerator
 LFX23961SW Refrigerator
 LFX25950SB Refrigerator
 LFX25950SW Refrigerator
 LFX25950TT Refrigerator
 LFX25960SB Refrigerator
 LFX25960ST Refrigerator
 LFX25960SW Refrigerator
 LFX25960TT Refrigerator
 LFX25961SB Refrigerator
 LFX25961ST Refrigerator
 LFX25961SW Refrigerator
 LFX25971SB Refrigerator
 LFX25971ST Refrigerator
 LFX25971SW Refrigerator
 LFX25975SB Refrigerator
 LFX25975ST Refrigerator
 LFX25975SW Refrigerator
 LFX25980ST Refrigerator
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Last edited by winxile : 09-24-2010 at 08:43 AM. Reason: Incomplete and corrections
  #2 (permalink)
Old 09-24-2010, 10:05 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by winxile View Post
Hi there,
W,
Why did you replace your original fridge ?
Yes , Low Voltage or a weak wired circuit could effect the operation and damage a new units motor, and not just a refrigerator, any electrical product can be affected by high or low voltage.
With Low voltage the circuit breaker may not and usually does not trip open,
Did you notice if the lights in the room went dim, at any time, this is a good indication of a low voltage problem.
Also, I would expect you to hear a number of clicks , rattles or hums from the refrigerator back side when it was trying to start or run.
I don't think you had a power problem, based on your description and the fact you had a fridge in the same outlet before.
But it is a possibility.
You can check for a voltage problem, by using a meter set for AC Volts, and checking the voltage at the outlet. then plug something into the outlet(something with a motor) and check the voltage drop when the motor starts. Any Drop of 10% or more would indicate a weak wired circuit or low voltage.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-24-2010, 11:16 AM
Junior Member
Default
Quote:
Originally Posted by Joe / APP Team View Post
W,
Good Luck,
Thanks for the quick response Joe !
The reason we replaced the old fridge is that it was getting old and leaking water (although after reading some of the posts we could have repaired it simply enough it seems) !
We had noticed no unusual sounds from the fridge or dimming of lights in the house.
Will buy a multimeter and test the outlet before switching on the new fridge just in case.
  #4 (permalink)
Old 09-24-2010, 11:32 AM
Senior Expert
Default
Ok, then,
I don't really see a problem with the next unit.
Something minor, probably happenned during production or transport.
Loose connection on a wire or component, something like that.
But, I would check the voltage, just to be safe and eliminate that possibility.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
started up s/s fridge. freezer working fine, but fridge is not cooling dkusko Refrigerator & Freezer Repair 0 09-05-2010 09:40 AM
Fridge not working but Freezer is working fine Kamal Refrigerator & Freezer Repair 1 08-23-2010 02:11 PM
Fridge on fridge freezer not working hyphenlh Refrigerator & Freezer Repair 2 06-04-2009 05:24 AM
Fridge too Warm Freezer working; Now both not working daynasha Refrigerator & Freezer Repair 1 09-02-2008 06:04 AM
Fridge too Warm Freezer working; Now both not working daynasha Refrigerator & Freezer Repair 0 09-01-2008 09:14 AM
