| » Control power relay chatter |
Model Number: GD5RHAXNT00 Brand: Whirlpool Age: 1 - 5 years
When I open the fridg door, the power relay in the back control pc board W10135090 starts chattering. Fridg works normally except the control panel lights fail to work, but the door switch is ok. If I remove the switch entirely, it still chatters. Hope someone has seen this before.
Ads By Google Related Models
__________________
I am going to replace the control board. I tried spraying the board with non-residue cleaner but no change. I suspect it might be a wiring problem but failed to see any connector problems. Replacing relays usually will not fix this type of problem.
Will inform you if the new control board fixed the problem. As a side issue, the adaptive defrost counts the door closings, and with a lot of closings like that, it will probably defrost more frequently.
__________________
I have fixed mine on the back of the board the circuit line from the middle prong on the relay to its connection was burnt. I soldered a wire from each terminal using the solder on the connections worked like a charm.I will be getting a surge protector today. I got this fix off of fixya.com pyro44922 has some great pics.
| Display Modes | |
| Help replacing power relay | grapes | Oven Repair (including Ranges and Cooktops) | 10 | 12-31-2012 01:59 PM |
| Flamed out K2 relay on Whirlpool control board | quantum1976 | Dishwasher Repair | 0 | 12-17-2009 10:09 PM |
| Wiring a replacement control relay | dannyfarwin | Refrigerator & Freezer Repair | 3 | 10-26-2009 04:49 PM |
| control relay chatter | jsquail | Refrigerator & Freezer Repair | 2 | 12-18-2008 06:41 AM |
| Relay verses Switch Control Panel | Boater | Oven Repair (including Ranges and Cooktops) | 2 | 03-05-2008 08:34 AM |
