Discuss
Freezer is cold but fridge is wrm
 in
Refrigerator & Freezer Repair
The fridge warms up while the freezer seems to be Okay. Where can I find "defrost heater, defrost thermostat and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is cold but fridge is wrm
  #11 (permalink)
Old 07-24-2013, 01:36 PM
Junior Member
Shafi is on a distinguished road
Default GE model PDS22SCPALSS
The fridge warms up while the freezer seems to be Okay. Where can I find "defrost heater, defrost thermostat and defrost timer"? Are these inside the freezer or outside the unit. If it's inside, I don't see any place where I can open it and see where these parts are. There is only one screw inside the freezer, I unscrewed it but I don't know if that's the right thing to do. It's all plastic and I am afraid I'd break something.
Could you please direct me to where I can find the three parts I mentioned above?
  #12 (permalink)
Old 07-24-2013, 01:43 PM
Junior Member
stewbeans22 is on a distinguished road
Default
Get your model number and serial number and go to the tab on this page that says parts. There you can enter in your info and search the part and most of the time they will have a diagram on what to remove. If you don't have any luck post your make and model with model number here and I will try to help. If you do find it also just let us know. Good luck
  #13 (permalink)
Old 07-25-2013, 01:36 PM
Junior Member
Default
I think I said it wrong. When I said I can't find those parts, what I should have said was I can't locate them in the system where they are installed.
Model# PDS22SCPALSS
Serial# VF041648
  #14 (permalink)
Old 07-25-2013, 01:40 PM
Junior Member
Default
I understand but if you put it in the find parts it usually shows a schematic of the fridge.
  #15 (permalink)
Old 10-12-2014, 01:29 PM
Junior Member
forrestdad is on a distinguished road
Default same question different model GE PDS20SBRALSS
I can't seem to find the defrost timer or defrost thermostat for this model of GE 'Profile' bottom freezer (Mod.GE PDS20SBRALSS). Is it all electronic on a board somewhere? the cabinet drawings only come back with a hit for the defrost heater
  #16 (permalink)
Old 10-12-2014, 01:46 PM
Junior Member
Default
The timer should be by the temp controls in the fridge portion. You need to remove the cover in the back it will be there. The defrost thermostat is located in the bottom of fridge comportment. Remove the drawers then the bottom panel. You will see the coils and in the front it will be clipped to the coil. If you go to appliancespartspros.com if you put in the model number you should be able to get a pets diagram.
Stew
  #17 (permalink)
Old 10-12-2014, 01:48 PM
Junior Member
Default
My fridge does not have a circuit board. If they do have a circuit bird it would be located in the back on the bottom.
Good luck and keep us posted on your adventure.
Stew
  #18 (permalink)
Old 10-12-2014, 04:04 PM
Junior Member
Default
Thanks for the ideas.. I checked in the fridge cabinet only the big foam and plastic duct that directs cold air from freeze to fridge the rest is one big single continuous plastic mold. the temp is displayed digitally just behind the top of the main door (fridge'/freeze) but nothing in there but door switch and a housing for cabinet lights. There is an access panel in freezer where the 'ice dam beast' visits weekly but I saw no motor there or on the schematics. there may be a thermostat I missed. At the same time I have yet to see the mother board so the problem may well be a blind operator... I'll continue with the head bashing and thanks for your time and interest.
  #19 (permalink)
Old 10-12-2014, 04:16 PM
Junior Member
Default
Under the foam should be the coil. You will also see the heater that does the defrosting. Double check the full model number and repost please. I will have a look to the schematics and give my thoughts.
Stew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help troubleshoot Freezer cold, Fridge not as cold as it should be Marvinb Refrigerator & Freezer Repair 3 08-05-2010 12:08 PM
Another Fridge not cold, Freezer cold thread. pack66 Refrigerator & Freezer Repair 0 07-01-2010 07:04 AM
Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Refrigerator & Freezer Repair 5 06-19-2009 04:51 AM
freezer.fridge not cold and leaking into fridge fruitul Refrigerator & Freezer Repair 1 09-08-2008 03:20 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
