I am looking for a little walk thru and an answer to a couple questions about connecting my fridge water intake valve to my wall water output valve. Thanks in advance.
I am not a plumber...far from it. But my understanding is that I need a 1/4" Copper tube to connect the fridge and the water source coming out of the wall. I also require the tubing clamp, Ferrule & 1/4" Comp. nut to make the connection to the fridge input. All that said and being true. Are these items easy to come by? And if so where? Is this an easy job for an intelligent guy who can follow directions?
Jordan
