| » Need Help Diagnose the problem |
Model Number: TFX22CRDAWW Brand: GE Age: 5 - 10 years
Water spilling outside the Freezer side by side model and a block of ice build-up on inside floor. What do you beleive could be the problem?
Check for a clogged or frozen drain tube. You'll probably have to remove the inner panel to expose the evaporator coil area to do this. Pour hot water through the drain to clear it. If this doesn't work, gently probe the tube with a stiff wire.
If it's frozen, this may be an indication that there is a defrost problem. |
| Display Modes | |
| Help me diagnose the problem | TotalRecall | Refrigerator & Freezer Repair | 7 | 01-19-2010 09:34 AM |
| MAV7057AWW - how to remove front panel - diagnose pump problem | King1950 | Washer Repair | 2 | 08-01-2009 05:12 PM |
| GE Gas Range diagnose ignite problem | jonhunt | Oven Repair (including Ranges and Cooktops) | 1 | 04-28-2009 01:46 PM |
| Diagnose problem and how to fix it. | ernest | Washer Repair | 0 | 06-24-2008 12:26 PM |
| Dishwasher repair-diagnose problem | Scottbosch | Dishwasher Repair | 0 | 10-26-2007 04:07 PM |
