Discuss
Whirlpool Freezer with ice build up @ bottom
 in
Refrigerator & Freezer Repair
I have a Side x Side Whirlpool GOLD, model: GD25DFXFB01 Mfg date: 02/99 that has a sheet of ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Freezer with ice build up @ bottom
  #1 (permalink)
Old 10-04-2008, 09:28 PM
indelible5 indelible5 is offline
Junior Member
indelible5 is on a distinguished road
Default Whirlpool Freezer with ice build up @ bottom
Model Number: GD25DFXF801   Brand: Whirlpool   Age: 5 - 10 years
I have a Side x Side Whirlpool GOLD, model: GD25DFXFB01 Manufacturer date: 02/99 that has a sheet of ice that builds up on the bottom of the freezer section.
Now I have read that the drain might be clogged and to run some hot water down it to clear it. However, one I have not had a chance to locate it, and two I think that is only part of the problem as I have noticed the exterior sides of the unit are not hot any longer.
About two years ago I had to call a tech out because the unit would not cool any longer and the freezer was defrosting. He had came out and I believe he fixed something in the board, after which the unit operated as normal except I noticed the sides got hot which he mentioned was normal. Well the sides do not get warm any longer, I think this is my problem for ice building up at the bottom.
Current conditions of the unit: The fridge and Freezer both get cold, I can here the evap fan turn on and run, the ice maker still makes ice.
Current problems of the unit: Sheet of ice building up on bottom of freezer section, sides of unit no longer get warm/hot.
Any help as to what part(s) I should look into replacing would be great. I would like to place an order and get this thing fixed asap.
Thanks in advance,
indelible5
*edit* model: GD25DFXFB01 (found out its B01 and not 801)
Related Models
Whirlpool GD25DFXFB00
Whirlpool GD25DFXFB01
Whirlpool GD25DFXFB02
Whirlpool GD25DFXFB03
Whirlpool GD25DFXFN00
Whirlpool GD25DFXFN01
Whirlpool GD25DFXFN02
Whirlpool GD25DFXFN03
Whirlpool GD25DFXFT02
Whirlpool GD25DFXFT03
Whirlpool GD25DFXFW00
Whirlpool GD25DFXFW01
Whirlpool GD25DFXFW02
Whirlpool GD25DFXFW03
Whirlpool GD25DIXHB00
Whirlpool GD25DIXHB02
Whirlpool GD25DIXHS00
Whirlpool GD25DIXHS02
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
Whirlpool GD2SHAXKT02
Whirlpool GD2SHAXKT03
Whirlpool GD2SHAXLB00
Whirlpool GD2SHAXLB02
Whirlpool GD2SHAXLQ00
Whirlpool GD2SHAXLQ02
Whirlpool GD2SHAXLT00
Whirlpool GD2SHAXLT02
Last edited by indelible5 : 10-05-2008 at 01:33 AM. Reason: correction on model number
  #2 (permalink)
Old 10-07-2008, 10:19 AM
Junior Member
Default
Any suggestions on which parts to replace first?? I believe the problem is that the units walls no longer get warm/hot.. I am thinking its the defrost therm or heater... Please help
Is this the defrost Thermostat? The description is very brief and there is no thumbnail pic.. Model GD25DFXFB01 (#35) Bimetl-def Part Number: AP4299920 made by WHIRLPOOL
*EDIT: I found this helpful post by Adam that I will give a try later tonight to see what I can come up with. Here is the link for others whom might be in similar situations: Refrigerator/Freezer
  #3 (permalink)
Old 10-08-2008, 02:19 AM
Junior Member
Default
Ok, I picked up a digital multimeter and tested for continuity on the defrost therm and heater. The defrost therm reading does not change, so I believe that is the bad part. The heater reads a resistance of 34. when a setting of 200 is used in ohm section, so I believe it is still good. I am going to order the defrost therm and see if this solves my issues.
  #4 (permalink)
Old 10-09-2008, 11:32 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
Sounds like all you have is a plugged drain. remove the back cover in freezer the drain hole will be frozen over and you can't see it until you melt the ice. if it is still making ice chances are it is working and cooling properly
  #5 (permalink)
Old 10-09-2008, 02:17 PM
Junior Member
Default
Thanks for the suggestion although I have already done this. Everything is working fine except the defrost cycle. From some testing I believe the bi-metal is defective, a new one should arrive today. I will post results once I receive the part and get it installed.
  #6 (permalink)
Old 10-09-2008, 02:36 PM
Senior Expert
APP Volunteer
Default
iS THERE A LOT OF FROST BUILD UP ON THE BACK PANEL INSIDE OF FREEZER? a plugged drain usually isn't caused from a defrost problem and with a defrost problem the freezer and refrigerator sections wouldn't be cooling. The condenser is underneath the refrigerator in the machine compartment so you wouldn't feel heat transfer on the exterior walls.If the condensor is wrapped around side walls a person wouldn't feel as much heat when unit is cooled down and at operating temps ambient air temp also has a big part in heat transfer with condenser mounted internally inside side walls. There are three componants making up the defrost cycle, a timer,(mechanical or circuitry) a defrost thermastat and a defrost heater. Every lets say 10 hours the frig shuts off and the timer puts voltage to the defrost heater, when the defrost thermastat gets warm the contacts open and kills power to the heater then a short time later the timer turns the frig back on and it begins to cool again. Well when a componant fails it doesn't melt the frost off the evaporator and then the heavy frost on the coil causes the frig to warm up because the return air vent is plugged with frost and the fan cant circulate air around the evaporator which in turn causes the icemaker to quit working the refrigerator section runs at about 50 degrees and the freezer runs around 20 degrees causing ice cream to be soft and milk to spoil before expiration date. I will add depending on frig the defrost could occur according to compressor run time usage etc. but for the most part defrosts 2 times a day.
  #7 (permalink)
Old 10-20-2008, 11:34 AM
Junior Member
Default
Well the parts came very fast, thanks AppliancePartsPros!
I replaced the bi-metal anyhow since I ordered it, however as v2k04 stated it wasn't my problem. It seems that the clogged drain was the only issue. Everything seems to be fine at this time.
Thanks for the fast part delivery! I will buy parts again from here once the time comes, great people.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer ice build up johnnib99 Refrigerator & Freezer Repair 8 12-29-2008 05:28 PM
Whirlpool Freezer Ice Build-up burnetti Refrigerator & Freezer Repair 1 05-28-2008 08:19 PM
Freezer cold, evaporator fan not working, frost build up in freezer heretolearn2 Refrigerator & Freezer Repair 3 05-28-2008 03:45 PM
Freezer with ice build Bob M Refrigerator & Freezer Repair 2 03-07-2008 03:02 PM
ice build up in the bottom of the freezer lauder Refrigerator & Freezer Repair 1 08-22-2007 08:53 PM
