Discuss
Upright freezer won't drain to overflow pan
 in
Refrigerator & Freezer Repair
We've had this Woods frost free upright freezer for about 10 years and it works fine. But for some
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright freezer won't drain to overflow pan
  #1 (permalink)
Old 10-04-2008, 04:21 PM
DaveR DaveR is offline
Junior Member
DaveR is on a distinguished road
Question Upright freezer won't drain to overflow pan
Model Number: F17WCA1   Brand: -other-   Age: 5 - 10 years
We've had this Woods frost free upright freezer for about 10 years and it works fine. But for some time (maybe since we moved it around) the drain water line freezes where it goes through the bottom of the rear wall into the overflow line. So the condensation water freezes and builds up in the bottom of the freezer. Should there be some insulation, or something else down there to stop this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-06-2008, 02:32 PM
salhasan2003 salhasan2003 is offline
Junior Member
salhasan2003 is on a distinguished road
Default I have the same problem
Hi:
I have exactly the same problem with my side by side refregerator/freezer. Every once in a while I have ot us the hair drier to defrost it and remove chuncks of ice. If any one canhelp please e mail at salhasan2003@yahoo.com
Thanks,
  #3 (permalink)
Old 10-06-2008, 03:25 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
NO, But you can use a copper wire over the evaporator coils and place a straight part down into the hole to keep it from freezing. Although not recommended by WC Wood Co. Whirlpool says itcan be done and we have done several of the like that over the years.
If that doesn't sound appealing, get a defrost drain heater, part # SH250.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 10-06-2008, 06:31 PM
Junior Member
Default
What do you mean by "over the evaporator and a straight part down the hole" Is this the samr piece of wire so that the water runs down quicker instead of slowly running towards the hole? Please explain.
  #5 (permalink)
Old 10-07-2008, 06:07 AM
Senior Expert
APP Volunteer
Default
With the copper wire you make a "shepards hook' place the hook over a coil on the evaporator and the long straight part goes down and thru the drain hole a little bit to keep it from freezing.
Nat
__________________
  #6 (permalink)
Old 10-07-2008, 11:41 AM
Junior Member
Default
Thank you very much Nat. I'll try that. Appreciate all the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOW-TO fix upright freezer fan motor Grandsunset Refrigerator & Freezer Repair 1 09-23-2008 11:29 AM
upright freezer will only get to 20 alcapone Refrigerator & Freezer Repair 1 08-17-2008 08:33 PM
Upright Freezer Mik Refrigerator & Freezer Repair 8 03-31-2008 02:58 PM
Upright Freezer delongbeth Refrigerator & Freezer Repair 7 01-26-2008 04:57 PM
Upright Freezer Help cpinke15 Refrigerator & Freezer Repair 1 11-21-2007 11:29 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
