Discuss
KenMore Ice Maker
 in
Refrigerator & Freezer Repair
1st found the Motor-module was bad after IceMaker stopped making cubes. Then worked for about 3 weeks after replacing
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » KenMore Ice Maker
  #1 (permalink)
Old 10-03-2008, 01:40 PM
Jake Finch Jake Finch is offline
Junior Member
Jake Finch is on a distinguished road
Question KenMore Ice Maker
Model Number: 10656532400   Brand: Kenmore   Age: 1 - 5 years
1st found the Motor-module was bad after IceMaker stopped making cubes. Then worked for about 3 weeks after replacing the Motor -module . Next replaced with another Motor -module after IceMaker stopped making cubes again. NOW won't work at all. Won't fill with water and motor will not run. Put Motor -module assembly on bench used jumper cord to supply 115V to it. Motor went through complete cycle on bench. Checked incoming voltage at incoming plug in freezer (plug before the 5A inline fuse. No voltage there. Lights in freezer work along with everything else EXCEPT the icemaker Motor -module. Where could the incoming voltage line be open before reaching this plug?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2008, 02:52 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check the thermostat inside the icemaker.
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 10-03-2008, 03:07 PM
Junior Member
Default KenMore Ice Maker
If there is a thermostat on the inside of the icemaker how can that prevent No 115v at the incoming plug on the left side of the compartment? I'm checking the voltage at the plug with the unit unplugged from that incoming plug! Thanks
  #4 (permalink)
Old 10-04-2008, 01:46 PM
Junior Member
Question
Can someone tell me where does the 115v come from that powers the icemaker plug on the right side of the icemaker. By that I mean where does the incoming power on the black w white strip and the white wires feed from (115v)? A terminal connection? A Wiring bundle with no fuses? Where does the 115v break off to the various devices in the whole refriderator?
  #5 (permalink)
Old 10-05-2008, 11:36 AM
grangecam grangecam is offline
Junior Member
grangecam is on a distinguished road
Default voltage to Kenmore icemaker
I am having a similar problem as Jake. However, I am getting a voltage reading from the plug inside the freezer wall. the voltage is only 65 volts.
this seems odd, since the icemaker has a sticker on it which says 115V AC 60hz. Is there a voltage regulator somewhere else in the fridge? Should the icemaker be getting 115 volts? The motor works fine when connected to 115volts AC directly.
  #6 (permalink)
Old 10-05-2008, 03:46 PM
Junior Member
Question Voltage to KenMore Icemaker
GrangeCam, After seeing you post I went in with a VOM and see I do have what I would consider a "soft Voltage" of about 9V AC so I assume WE DO have the same problem!! I hope someone here can identify this problem for us!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Ice Maker JAMIE32 Refrigerator & Freezer Repair 0 09-28-2008 06:22 PM
Kenmore sxs ice maker non functional noiceman Refrigerator & Freezer Repair 0 07-19-2008 10:53 AM
Kenmore Ice Maker Not Making Ice bigcornfedtex Refrigerator & Freezer Repair 4 06-02-2008 06:29 PM
Kenmore Refrigerator ice maker not making ice jon r Refrigerator & Freezer Repair 0 04-12-2008 09:19 AM
Kenmore Ice Maker Supply Problem kmh1972 Refrigerator & Freezer Repair 0 01-23-2008 10:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
