Whirlpool side by side fridge drain pan over flowing. Has ice maker and water dispenser. Not sure what to look for first any sugesstions??
If you're talking about the drip pan under the unit, look to see if the condenser fan is running. It should run at the same time as the evaporator fan (inside the freezer) and the compressor. If the condenser fan isn't running, the water in the drip pan won't evaporate completely, and eventually, the drip pan will overflow.
OK cleaaned all the dust from the coils washed the fan blades and turned the power on...the fridge ran for 10 mins and shut down perhaps the thermostat has failed...the model is whirlpool er25rfxfw00 1998. temp inside got to 65 deg.
