Discuss
Side-by-Side: refrig warm, freezer cool
 in
Refrigerator & Freezer Repair
When it rains it pours. Last week, I had my Jenn-Air range's lower heating coil fail spectacularly doing
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Side-by-Side: refrig warm, freezer cool
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-24-2007, 04:07 PM
tkrotchko tkrotchko is offline
Junior Member
tkrotchko is on a distinguished road
Default Side-by-Side: refrig warm, freezer cool
Model Number: JRSD2490   Brand: Jenn-Air   Age: More than 10 years
When it rains it pours. Last week, I had my Jenn-Air range's lower heating coil fail spectacularly doing it's impression of a 1 foot long arc welder. Thanks to everybody for your help. I Replaced that on Friday, and now I came home and my refrigerator is warm.
Then, I realized the freezer is actually cold, although the refrigerator is warm.
I asked my son if it was open when he got home (he gets home before me), and he swears he didn't touch it.
So I assumed the cold air came in the top, pried off the light cover and found where the cold air inlet is. I cranked the refrigerator all the way up, and I felt cool air coming out. Not cold, but cool. I wish I had one of my old mercury filled thermometers to test, but I don't. So I'm making due with an outside thermometer in there.
So assuming the refrigerator door wasn't left open all day (and that is still a possibility in my mind), I'm assuming that something is either clogged or not blowing so the air is not getting to where it's supposed to be.
How should I diagnose it? Thanks for any help.
--Tom
Further Update 9 hours later:
It turns out neither freezer nor refrigerator are cooling as they should.
I've removed the back wall of the freezer and it looks like it just went through a defrost cycle, and there was no ice on the coils. I left the back off to observe the coils and they developed a fair amount of condensation/frost, but this might be due to the fact that I had the freezer open for a while.
The compressor/condenser is underneath and the fan is definitely blowing across the condenser.
Nonetheless, the refrigerator is struggling to get the internal temperature much below 55 degrees, and while the freezer must be below 32 degrees, it is certainly not close to 0.
Last edited by tkrotchko : 09-25-2007 at 12:03 AM. Reason: More info/correct mistake
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-25-2007, 03:03 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the freezer coils are only half frozen, you have refrigeration problems. Either a refrigerant leak, or a bad compressor/clogged capillary. Make sure your condensing fan is running and condenser coils clean.
__________________
  #3 (permalink)
Old 10-28-2007, 11:36 AM
Carolyn Carolyn is offline
Junior Member
Carolyn is on a distinguished road
Default Jenn Air Side By Side
We recently were given an Jenn Air side by Side refrigerator and we are having problems...either the freezer is too warm and thawing out food and the fridge is too warm...OR the freezer is working and the fridges is freezing food. What can we do? Is this fixable?
  #4 (permalink)
Old 10-28-2007, 12:04 PM
Junior Member
Default
Quote:
I don't know... It appeared to me that my problem was a refrigeration problem and that because of the age of the refrigerator it wasn't worth repairing, particularly since the new ones use half the electricity of the old one.
But what I would do is remove the back wall of the freezer (it's about 10 screws or so) and observe the coils. Note that I don't mean literally the back of the unit, it's on the inside... the back wall of the freezer. It's a pain because there's not enough clearance, but it can be done.
If there is ice all over them, then it's probably an issue with the defroster (that happened once to mine). In my case it simply wasn't cooling; I think the compressor was shot on mine.
But do that and report back what you see exactly. It would even help if you could post a picture (if that can be done in this forum).
  #5 (permalink)
Old 10-28-2007, 07:19 PM
Senior Expert
APP Volunteer
Default
You have a classic case of low refrigerant or a worn compressor. Either one is big bucks or just bad news of constant repair. A check of freezer coils would confirm this. Or you could just have a bad condensing fan.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Side by Side Going through defrost mode at top ref. and freezer briant97 Refrigerator & Freezer Repair 1 09-18-2007 06:16 AM
fridge side warm but freezer is cold shthd2u Refrigerator & Freezer Repair 1 09-08-2007 11:15 PM
side by side Refrig/Freezer gonzorog Refrigerator & Freezer Repair 1 09-05-2007 11:48 PM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 05:38 PM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 08:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
