Dear Sirs;
My Fridge quit cooling about a month ago and I unplugged it and called for a technician. I plugged the unit in about an hour or two before he showed up and it was working perfect. I was told that there was nothing he could do as it was working fine, so I paid him for the service call and he smiled all the way to his van. I would too. The unit has stopped again and am wondering which parts are suspect. The motherboard, the compressor the pctr or the overload. The fan is running, the compressor does not come on, and there is no hot or cold touch on any refrigerant lines. I tried the unplug and let it rest trick, but no results. Any thoughts?
thank you, pal
