Discuss
Auger Motor Technical Support Question
 in
Refrigerator & Freezer Repair
When I place a cup to the dispenser and press the lever, it acts as if it is about to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Auger Motor Technical Support Question
  #1 (permalink)
Old 09-13-2010, 05:20 PM
Junior Member
BIGHURTDABEAST is on a distinguished road
Default Auger Motor Technical Support Question
Model Number: 241691311   Brand: Frigidaire   Age: 1 - 5 years
When I place a cup to the dispenser and press the lever, it acts as if it is about to dispense ice; however, the only ice that dispense is about 3 cubes that drop through the hole when the flap opens. I unhooked the plastic cover to expose the auger motor and noticed a box that is wired/connected to the actual auger motor and has a rod that sticks out of the box and also had a spring on it. There was no firmness to that spring and it looked as if the spring served no purpose. There was also a space in the plastic piece that surrounded the rod and spring where the rod that run under the ice tray set and look like it is supposed to move up or down and move that plastic piece so that the box it is sticking in may trigger the motor. I also pulled the rod up and noticed a slit that sit under or behind the rod where something may have set that kept the rod in the box or is supposed to help move the rod inside the box to allegedly trigger the motor to turn the auger so that it may dispense ice. If anyone have any knowledge on what I need to do, that would be very much appreciated. Thank you in advance.
Ads By Google
Related Models
Frigidaire 2418A GAS RANGE
Frigidaire 2418B GAS RANGE
Frigidaire 2420A GAS RANGE
Roper 2424*0A Ranges, Electric*
Roper 2424*1A Ranges, Electric*
Roper 2424W0A Ranges, Electric*
Roper 2426*0A Ranges, Electric*
Roper 2426*1A Ranges, Electric*
Roper 2426*2A Ranges, Electric*
Roper 2426W0A Ranges, Electric*
Roper 2426W1A Ranges, Electric*
Roper 2426W2A Ranges, Electric*
Frigidaire 2427A GAS RANGE
Roper 2428000 Ranges, Electric*
Frigidaire 2428A GAS RANGE
Frigidaire 2428B GAS RANGE
Roper 2438000 Ranges, Electric*
Frigidaire 2438A GAS RANGE
Frigidaire 2440A GAS RANGE
Frigidaire 2447A GAS RANGE
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Frigidaire 2448A GAS RANGE
Frigidaire 2448B GAS RANGE
Frigidaire 2450A GAS RANGE
Frigidaire 2450C GAS RANGE
Frigidaire 2450E GAS RANGE
Roper 2453*9A Ranges, Electric*
Roper 2453*AA Ranges, Electric*
Roper 2453W0A Ranges, Electric*
Roper 2453W9A Ranges, Electric*
Roper 2453WAA Ranges, Electric*
Roper 2454X0A Ranges, Electric*
Roper 2454X1A Ranges, Electric*
Roper 2454X2A Ranges, Electric*
Roper 2454X3A Ranges, Electric*
Roper 2456X0A Ranges, Electric*
Roper 2456X1A Ranges, Electric*
Roper 2456X2A Ranges, Electric*
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
Frigidaire 2458A GAS RANGE
Frigidaire 2467A GAS RANGE
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
Frigidaire 2468A GAS RANGE
Amana 2474.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 2475 SURFACE UNIT- DDRAFT ELE
Amana 2476.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 2477A GAS RANGE
Frigidaire 2478A GAS RANGE
Frigidaire 2478B GAS RANGE
Jenn-Air 2480 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2485 SURFACE UNIT- ELE
Jenn-Air 24882 JENN-AIR REFRIGERATOR
Frigidaire 2488A GAS RANGE
Jenn-Air 2490 SURFACE UNIT- ELE
Roper 2492*0A Ranges, Electric*
Roper 2492*1A Ranges, Electric*
Amana 2492.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 2492L0A Ranges, Electric*
Roper 2492L1A Ranges, Electric*
Roper 2492X0A Ranges, Electric*
Amana 2494.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.C MWAVE - FAMILY SIZE (60 HZ)
Amana 24940.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2496*0 Ranges, Electric*
Roper 2496*0A Ranges, Electric*
Roper 2496*1 Ranges, Electric*
Roper 2496*1A Ranges, Electric*
Roper 2496*2 Ranges, Electric*
Roper 2496*2A Ranges, Electric*
Roper 2496X0 Ranges, Electric*
Roper 2496X1 Ranges, Electric*
Roper 2496X2 Ranges, Electric*
Amana 24C3SS ROOM AIR CONDITIONER
Frigidaire 24CGMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN1 Tap(v1) / Gas Range
Frigidaire 24CPMCWBN2 Tap(v2) / Gas Range
Frigidaire 24DEMBWAD4 Tap(v1) / Electric Range
Magic Chef 24FA-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FA-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FA-6CKXWV8-DY RANGE- S/C MWAVE GAS
Magic Chef 24FK-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FK-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FK-6CKXWV8-DY RANGE- S/C MWAVE GAS
Magic Chef 24FN-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FN-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FN-6CKXWV8-DY RANGE- S/C MWAVE GAS
Magic Chef 24FS-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FS-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FS-6CKXWV8-DY RANGE- S/C MWAVE GAS
Magic Chef 24FY-6CKXW WALLOVEN-S/C DBL OVEN GAS
Magic Chef 24FY-6CKXWV8 RANGE- S/C MWAVE GAS
Magic Chef 24FY-6CKXWV8-DY RANGE- S/C MWAVE GAS
Frigidaire 24HA241
Frigidaire 24HA241A
Frigidaire 24KEMAWAD3 Tap(v1) / Electric Range
Frigidaire 24KEMAWAD4 Tap(v2) / Electric Range
Frigidaire 24KEMAWAD5 Tap(v3) / Electric Range
Frigidaire 24KGMAWAN4 Tap(v1) / Gas Range
Frigidaire 24KGMAWAN6 Tap(v1) / Gas Range
Frigidaire 24KGMAWAN6-23 Tap(v2) / Gas Range
Frigidaire 24KPMAWAN4 Tap(v1) / Gas Range
Frigidaire 24KPMAWAN4-32 Tap(v2) / Gas Range
Frigidaire 24KPMAWAN5 Tap(v3) / Gas Range
Frigidaire 24KPMAWAN5-32 Tap(v4) / Gas Range
Frigidaire 24KPMAWAN7 Tap(v5) / Gas Range
Frigidaire 24KPMAWAN7-32 Tap(v6) / Gas Range
Amana 24M33PA ROOM AIR CONDITIONER
Magic Chef 24MA-7CKXWV8 RANGE- STD MWAVE GAS
Magic Chef 24MN-7CKXWV8 RANGE- STD MWAVE GAS
Thermador 2501
Hardwick 2506 GAS RANGE
Frigidaire 2507A GAS RANGE
Frigidaire 2509A GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Auger Motor on Refrigerator monk185@sbcglobal.net Refrigerator & Freezer Repair 3 02-19-2010 06:52 AM
Auger Motor not turning nharleydon Refrigerator & Freezer Repair 0 11-09-2009 06:54 AM
auger motor trane166 Refrigerator & Freezer Repair 2 01-03-2009 05:53 PM
Ice Maker Auger Motor Robert Stolarski Refrigerator & Freezer Repair 9 04-01-2008 09:31 PM
