Discuss
Refrig keeps running
 in
Refrigerator & Freezer Repair
Wife left the freezer open and there was a lot of condensate in it. I emptied everything out, wiped it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrig keeps running
  #1 (permalink)
Old 09-27-2008, 03:06 PM
Junior Member
ningauble42 is on a distinguished road
Default Refrig keeps running
Model Number: BX21VL   Brand: Amana   Age: More than 10 years
Wife left the freezer open and there was a lot of condensate in it. I emptied everything out, wiped it down (even taking the back off to wipe stuff in the evaporator area) and reassembled. Turned it back on at it just kept running. It got to below zero F in the freezer. I did turn it back off, waited a minute and then turned it back on and the compressor has not kicked in. I don't know if it needed a reset or there is something wrong.
I think I need a new thermostat, but could not find it in your parts area (by the way, nice parts area).
I found the defrost thermostat, but not the thermostat assembly, which I would think would be somewhere in the evap & freezer control assy.
Thanks for the help
Thurston
Related Models
Amana BX21VL REF - BOTTOM MOUNTS
Amana BX21VW REF - BOTTOM MOUNTS
Amana BX22A2E REF - BOTTOM MOUNTS
Amana BX22A2L REF - BOTTOM MOUNTS
Amana BX22A2W REF - BOTTOM MOUNTS
Amana BX22A5L REF - BOTTOM MOUNTS
Amana BX22A5W REF - BOTTOM MOUNTS
Amana BX22R3E REF - BOTTOM MOUNTS
Amana BX22R3L REF - BOTTOM MOUNTS
Amana BX22R3W REF - BOTTOM MOUNTS
Amana BX22RE REF - BOTTOM MOUNTS
Amana BX22RL REF - BOTTOM MOUNTS
Amana BX22RW REF - BOTTOM MOUNTS
Amana BX22S5E REF - BOTTOM MOUNTS
Amana BX22S5L REF - BOTTOM MOUNTS
Amana BX22S5W REF - BOTTOM MOUNTS
Amana BX22TE REF - BOTTOM MOUNTS
Amana BX22TL REF - BOTTOM MOUNTS
Amana BX22TW REF - BOTTOM MOUNTS
Amana BX518VE REF - BOTTOM MOUNTS
Amana BX518VW REF - BOTTOM MOUNTS
Amana BX521VCPER REF - BOTTOM MOUNTS
Amana BX521VCPSR REF - BOTTOM MOUNTS
Amana BX521VCPWR REF - BOTTOM MOUNTS
Amana BX521VE REF - BOTTOM MOUNTS
Amana BX521VW REF - BOTTOM MOUNTS
Amana BXF19TL REF - BOTTOM MOUNTS
Amana BXF19TW REF - BOTTOM MOUNTS
Amana BXI21VE REF - BOTTOM MOUNTS
Amana BXI21VL REF - BOTTOM MOUNTS
Amana BXI21VW REF - BOTTOM MOUNTS
Amana BXI22S5E REF - BOTTOM MOUNTS
Amana BXI22S5L REF - BOTTOM MOUNTS
Amana BXI22S5W REF - BOTTOM MOUNTS
Whirlpool BYCCD3421W0 COMPACT ELECTRIC DYER
Whirlpool BYCCD3421W1 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W2 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3421W3 COMPACT ELECTRIC DRYER
Whirlpool BYCCD3921W0 ELECTRIC DRYER
Whirlpool BYCD3722W0 DRYERS
Whirlpool BYCD3722W1 ELECTRIC DRYER
Whirlpool BYCD3723W0 DRYERS
Whirlpool BYCD3723W1 GAS DRYER
Whirlpool BYCD3723W2 DRYER
Whirlpool BYCD4932W0 ELECTRIC DRYER
Whirlpool BYCD4933W0 GAS DRYER
Whirlpool BYCW4271W0 DIRECT-DRIVE WASHER
Whirlpool BYCW6292W0 WASHER
Whirlpool BYCWD6274W0 LAUNDRY COMBINATION UNITS
Whirlpool BYCWD6274W1 WASHER / DRYER COMBINATION UNIT
Whirlpool BYCWD6274W2 WASHER/DRYER COMBO
Whirlpool BYCWD6274W3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool BYCWD6274W4 WASHER/DRYER LAUNDRY SYSTEM
Amana BZ20QE REF - BOTTOM MOUNTS
Amana BZ20QG REF - BOTTOM MOUNTS
Amana BZ20QL REF - BOTTOM MOUNTS
Amana BZ20QW REF - BOTTOM MOUNTS
Amana BZ20R REF - BOTTOM MOUNTS
Amana BZ20RE REF - BOTTOM MOUNTS
Amana BZ20RG REF - BOTTOM MOUNTS
Amana BZ20RL REF - BOTTOM MOUNTS
Amana BZ20RW REF - BOTTOM MOUNTS
Amana BZ22QE REF - BOTTOM MOUNTS
Amana BZ22QL REF - BOTTOM MOUNTS
Amana BZ22QW REF - BOTTOM MOUNTS
Amana BZ22R3E REF - BOTTOM MOUNTS
Amana BZ22R3L REF - BOTTOM MOUNTS
Amana BZ22R3W REF - BOTTOM MOUNTS
Amana BZ22R5L REF - BOTTOM MOUNTS
Amana BZ22R5W REF - BOTTOM MOUNTS
Amana BZ22RE REF - BOTTOM MOUNTS
Amana BZ22RL REF - BOTTOM MOUNTS
Amana BZ22RW REF - BOTTOM MOUNTS
Jenn-Air C SURFACE UNIT- DDRAFT ELE
Hardwick C-413 SURFACE UNIT- GAS
Hardwick C-414 SURFACE UNIT- GAS
Hardwick C-423 SURFACE UNIT- GAS
Hardwick C-424 SURFACE UNIT- GAS
Hardwick C-433 SURFACE UNIT- GAS
Hardwick C-434 SURFACE UNIT- GAS
Hardwick C-443 SURFACE UNIT- GAS
Hardwick C-444 SURFACE UNIT- GAS
Jenn-Air C100 SURFACE UNIT- DDRAFT ELE
Amana C100DW FREEZER- CHEST
Amana C100FW FREEZER- CHEST
  #2 (permalink)
Old 09-28-2008, 05:01 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
If your wife left the door open, the compressor is so hot it could fry an egg. The best thing you can do is unplug the refrigerator for about three hours, and then turn it on. That compressor needs some time to cool down. Tom ********************************************
  #3 (permalink)
Old 09-30-2008, 02:55 PM
Junior Member
Default Frig fixed!!
Yes, I shut it down for a few hours. I also found that there was so much moisture in the frig that the defrost system was confused. It took a while for it to get the moisture out of the system.
Everything seems to be working fine now. $400+ saved!!!
Thanks,
Thurston
  #4 (permalink)
Old 09-30-2008, 03:19 PM
Senior Expert
APP Volunteer
Default
There you have it. That is the way to save the cash. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana refrig not running (has power) reidjantz Refrigerator & Freezer Repair 3 07-14-2009 06:37 PM
Frezzer is Fine Refrig is Warm - Fan is running Chrish Refrigerator & Freezer Repair 3 05-30-2009 12:18 PM
Water running from freezer to refrig. Joe2009 Refrigerator & Freezer Repair 5 03-13-2009 11:51 AM
Refrig Running Hot BRI129 Refrigerator & Freezer Repair 10 06-12-2008 01:56 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
