I am trying to locate a manual that will show me the proper way to adjusr the door, The freezer is level but the door is about 3/4" low on the non henge side. I replaced the gasket and there are places that the new gasket dose not bellow out like it should. I have followed the directions of newer models that look the same, but have had no luck.
