HI, I recently left both fridge doors open to air out while the house was empty and the power was off. The power was unexpectedly turned on and therefore the fridge ran like that for several hours. When I arrived to check it it was running but not cold so i shut it hoping it was ok. the next day I checked it and it was not cold and not running. Now when i plug it in it will buzz briefly then quit. Please tell me there is a safety feature or reset button somewhere and its not shot!
Replace the compressor start relay and the overload. If it would help, the compressor probably has gone bad. - The start relay Part number: AP3796066
Ok thank you I will try that
