| » GE Side by side won't dispense ice; intermittent dispense of water |
Model Number: pss26sgress Brand: GE Age: 1 - 5 years
My GE ge pss26sgress side by side refrigerator has stopped dispensing ice (the ice maker still works and makes lots of ice), and only intermittently dispenses water.
If I select cubed or crushed ice, the green light comes on for the appropriate selection. However, if I push the triggering lever arm, the green light either goes dim or goes out completely. If I select the water dispenser it sometimes works and sometimes doesn't. If the green light is bright when I select water, then it works. If the light is dim when I select water, then it won't work. Sometimes it will go from dim to bright while I am holding the lever arm depressed. When this happens water comes out. I have seen web sites that say this indicates a bad main control board. However, that item is expensive and I would like a confirmation of this diagnosis before I buy it. Thanks Ralph Ads By Google Related Models |
Ralph,
Most likely the problem is a bad main control board. A dimmed lights proves it. - The main control board Part number: AP4436216 Here are the breakdown diagrams and Replacement parts for General Electric PSS26SGRESS Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Ice dispenser stoped working. Replaced dispenser control board WR55X10195 once, and Main control board WR55X10942 twice. Both times the ice dispenser worked for a short time then quit again. All dispenser button lights are out and nothing on the dispenser works. Are there any other controles to check, or any other possible causes? This is getting expensive.
Quote:
__________________
It sounds very strange. Possible a shorted wires somewhere. Probably it is a time to call a pro.
__________________
| Display Modes | |
| side by side refrigerator - fridge side freezing food, water coming out of freezer | bomb | Refrigerator & Freezer Repair | 8 | 08-30-2011 01:58 PM |
| GE Smart Dispense does not dispense | chipkozy | Dishwasher Repair | 0 | 11-03-2009 11:55 AM |
| Intermittent water leak - Kitchen Aid side by side | greg88 | Refrigerator & Freezer Repair | 1 | 10-08-2009 01:13 PM |
| GE side by side won't dispense ice | tombstonegene | Refrigerator & Freezer Repair | 0 | 03-27-2009 10:39 AM |
| ge side by side ice maker works will not dispense h20 | poolguy7d4 | Refrigerator & Freezer Repair | 1 | 04-16-2008 03:42 PM |
