hvusau
#1 Posted : Wednesday, September 24, 2008 8:22:29 AM(UTC)
hvusau
Whirpool refrigerator intermittent not restart. once it is going everything going good. (making ice, both freezer and refri area are cold as normal). it ran for about a day and stop. sometime it can't start automatically. when it can not start the condensor fan is running but not the compressor nor the evaporator fan. I unplug for few minutes and plug in then it going again. What went wrong for the fridge? is the probem with run capacitor or restart relay -not enough power? what need to be fix and what would it cost to fix the problem. thanks in advance for your reply. already replace with new the defrost timer.
libertyappl
#2 Posted : Wednesday, September 24, 2008 8:46:23 AM(UTC)
libertyappl
I would suggest the start device/overload & the capacitor maybe getting weak. Start device/Overload part # 8201799 Capacitor # 4387764.
Nat
hvusau
#3 Posted : Wednesday, September 24, 2008 9:36:59 AM(UTC)
hvusau
Thanks for quick reponse.
do you have instruction or diagram for replacing these suggest components (relay, overload, capacitor). thx again.
libertyappl
#4 Posted : Wednesday, September 24, 2008 9:44:36 AM(UTC)
libertyappl
These are pretty much just unplug the old and plug in the new and most of the time the start device/overload will come with the instructions sheet.
nat
hvusau
#5 Posted : Wednesday, September 24, 2008 10:19:18 AM(UTC)
hvusau
where is the capacitor mounted on this fridge? is this together with start device and overload. thx
libertyappl
#6 Posted : Wednesday, September 24, 2008 10:28:47 AM(UTC)
libertyappl
it's next to the start device.
Nat
Drags1998
#7 Posted : Wednesday, September 24, 2008 3:08:26 PM(UTC)
Drags1998
The 8201799 comes with a very good manual in the box, It also comes with 2 overloads for different Models, Very easy to install and is most likely your problem!!! Good Luck!!!:)
hvusau
#8 Posted : Thursday, September 25, 2008 7:15:40 AM(UTC)
hvusau
Thanks for all your help.
