This side-by-side has the in-door water/ice dispenser. Everything works fine but when you set the switch to "ICE" and activate the dispenser, you hear the solinoid click and the door to the bin opens but the auger motor will not operate to move the ice to the chute. Is this a problem with the switch, auger motor or is there another relay or something that operates that motor?
