Our side by side refrigerator came with the house we bought that was built in 1995 so I assume the refrig is the same age. i noticed the freezer doesn't go below 10 degrees and the refigerator stays around 30 degrees. Also, the ice cubes in the container tends stick together like they melt & then freeze again. The freezer is set for maximum (E coldest) and the refrigerator is set for (3 with 9 being coolest).
Is there something I can do or should I call a repairman. BTW, this is a summer house that we use only 4 months a year and the refrigerator is turned off during the winter. I cleaned the coils last year.
