fer. wouldn't run .replace board ref came on evap. would not run replace motor.now everything works but ref. not cold enough. frezzer ok. replace damper coltrol.no help. adjust ref.door still no help. ref about 60 % freezer 5% no frost block on evap coil.
did you follow the directions for replacing the board regarding cutting the wire in pin2 of the j2 connector. If you have a wire in pin 1 and 2 you need to cut the wire in pin 2. Otherwise the airflow damper will not open to allow cold air in the refer section
