| » sub zero 532 - compresser will not stay on, refrig not cold |
Model Number: 532 Brand: Sub Zero Age: More than 10 years
I have a sub zero 532 - refrig will not get cold. I realize the compresser will not stay on. It kicks on for about 3 seconds and turns off. A few minutes later it does the same thing again. Any advice will be helpful. I am trying to decide if it pays to have the unit repaired /or compressor replaced?
Thanks in advance, Maytag Related Models |
I tried bypassing the thermostat. Problem continued but after a while the compressor seems to run continuosly. Wld a new thermostat fix this or is it something more involved that caused the compressor to shut down so quick? Thanks
Hi Maytag,
How hot is the compressor? Very likely the condenser coil is full of lint, causing the compressor to overheat. Also make sure the fan next to the condenser is running. Turn the refrigerator "off", clean the condenser and turn the refrigerator "on" after the compressor cooled down. Hopefully the compressor is not damaged yet. This refrigerator is very expensive and if it is in good shape then it's worth any repairs. Gene.
__________________
Professional appliance repair in Orange County, California. |
Quote:
Quote:
You found at least one problem (bad thermostat) and you can not proceed further until you'll replace it. Gene.
__________________
| Display Modes | |
| Refridgerator will not stay cold | jmichelle24 | Refrigerator & Freezer Repair | 3 | 08-18-2008 08:48 PM |
| New Pin on side of refrig won't stay in | terri barnett | Refrigerator & Freezer Repair | 0 | 06-13-2008 01:59 PM |
| Refrig not cold | bwall117 | Refrigerator & Freezer Repair | 7 | 04-13-2008 05:40 PM |
| Freezer Cold,But refrig warm | oceanrunner | Refrigerator & Freezer Repair | 1 | 11-23-2007 07:32 PM |
| Refrig not cold | bc1 | Refrigerator & Freezer Repair | 0 | 11-06-2007 03:01 PM |
