| » center wall is warm |
my first impression is you have a condenser fan motor that has stopped. this could be from debris (possibly also a dead mouse ( ick i know)). the condenser fan is in the back at the bottom behind a cardboard panel. if no debris but the fan is not turning you may need to replace the condenser fan motor. good luck and post your results
__________________
Just a little addition of my two cents, if the condenser fan is working make sure the coils are clean. my first impression would be make sure the evaporator fan in the back of the freezer is working, if not it's not blowing cold air into the frig side. Depending on the exact model you have there also could be a damper which is closed.
For better opinions post your model number off the unit, normally there's a tag inside the frig. Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
This still confounds me. But first, it is a Kenmore model 106.9555913.
The fridge is cold, the freezer is freezing. The condenser fan is running, and I have cleaned the coils. But the center wall -- that separates the fridge from the freezer -- is still warm, almost hot, to the touch. Right next to the icemaker. Something in the front of that center wall -- the forward section that contacts the doors when they close -- is generating heat. What could possibly be the heat source here? I believe in science, and even took a course in Thermodynamics in college. There must be a reason for this! -- daddyjohn |
Your Kenmore refrigerator was made by Whirlpool, that's what to 106 tells us.(Kenmore doesn't make anything) the center divider is hot because there's a heater that is called a mullion heater inside there and it's normal for them to get hot, helps keep the moisture down from condensation between the 2 center wall liners.
Nat
__________________
Nat,
That is fascinating. I'm going to google the mullion heater, and learn a little more. Is it normal for this to alway be heating? It seems like this would decrease the efficiency of the unit. I appreciate the benefit of your insight! -- daddyjohn |
It does turns on & off kind of like the defrost timer. One thing that does seem to help is to make sure the coils underneath are cleaned regularly. I know it sounds weird but it helps. And it needs to be one at least once a year anyway.
Nat
__________________
| Display Modes | |
| warm frige. no light center bar between fridge and freezer so hot it burns you | mike1995 | Refrigerator & Freezer Repair | 0 | 09-06-2009 12:42 PM |
| Both elements in wall oven-warm-not hot | georgia joe | Oven Repair (including Ranges and Cooktops) | 0 | 06-29-2009 04:58 PM |
| Both elements in wall oven-warm-not hot | georgia joe | Oven Repair (including Ranges and Cooktops) | 0 | 06-29-2009 04:49 PM |
| Jenn Air Wall Electric Wall Oven | WILLIAM SHIVER | Oven Repair (including Ranges and Cooktops) | 3 | 05-20-2009 12:56 AM |
| Electric Double Wall Oven Warm, not Hot | jcrump55 | Oven Repair (including Ranges and Cooktops) | 2 | 11-12-2007 07:36 PM |
