Discuss
Cold Control shuts off compressor when switched 'off' but won't turn back on...
 in
Refrigerator & Freezer Repair
While the fridge is in normal operating mode; when I slide the Cold Control from the fresh food compartment to '
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Cold Control shuts off compressor when switched 'off' but won't turn back on...
  #1 (permalink)
Old 09-13-2008, 02:21 AM
80sGuy 80sGuy is offline
Junior Member
80sGuy is on a distinguished road
Default Cold Control shuts off compressor when switched 'off' but won't turn back on...
Model Number: PTB1949GRW   Brand: Maytag   Age: 5 - 10 years
While the fridge is in normal operating mode; when I slide the Cold Control from the fresh food compartment to 'off'; everything stops, but when I slide it back to 'on' at around mid level; all the fans came back on except for the compressor. I also hear a 'click' from the start relay about 25-30 seconds later but there's no 'humming' to the compressor and it is still off.
The only way to get the compressor running again is if I:
*leave the Cold Control set to 'on',
*unplug the power cord and then wait for another 'click',
*plug the power cord back in to the ac outlet
After this procedure, then the compressor and everything else would come back to normal again.
Is this normal, and will the compressor start again if I waited longer without unplugging it? I read somewhere that if I turned the fridge 'off' with the cold control, it would manually trigger to 'defrost mode'??? Need help!!!
FYI: 'Overload/Relay Kit' and 'Run Capacitor' was newly installed two weeks ago.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-13-2008, 03:57 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
All the indications are for a hard start compressor. If you turn it off, then on, the compressor will normally have trouble starting till the pressures equalize. If the compressor takes much longer to start than normal after turning off, you have a bad start winding in the compressor.
Usually a good compressor will start after one or two minets of equalization time.
__________________
  #3 (permalink)
Old 09-13-2008, 12:34 PM
Junior Member
Default
I didn't wait that long for the compressor to respond because I didn't know what the outcome would be. So the next time if I turned the lever to 'off' should I wait for a minute or so for it to come back on? Everything works fine once it starts and it cycles on/off fine pretty much on time.
  #4 (permalink)
Old 09-13-2008, 01:23 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
80's guy, If you turn it off or unplug it, you MUST WAIT!!!!! at least 5min. before attemping to RESTART, You are putting a HUGE load on the Relay-Overload, Which WILL HURT STUFF if you keep it up!!!
  #5 (permalink)
Old 09-13-2008, 02:38 PM
Junior Member
Default
Quote:
Good to know. Thanks!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
huge viabration before the compressor shuts off hu1992@yahoo.com Heating, Ventilation, and Air Conditioning (HVAC) 1 07-15-2008 08:59 PM
No Display or Control - Can't turn on dryer Mark_W Dryer Repair 0 06-27-2008 09:08 PM
buttons of control module do not pop back marc chelico Dishwasher Repair 0 03-03-2008 09:34 AM
temperature control shuts off thehun Oven Repair (including Ranges and Cooktops) 3 02-19-2008 02:17 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
