Discuss
Refrigerator not cooling
 in
Refrigerator & Freezer Repair
Hi, The fresh food section was getting warmer and freezer was cool. So I thought the air circulation is not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling
  #1 (permalink)
Old 09-11-2008, 11:55 AM
MGL MGL is offline
Junior Member
MGL is on a distinguished road
Default Refrigerator not cooling
Model Number: ET9FTTXLQ12   Brand: Whirlpool   Age: 5 - 10 years
The fresh food section was getting warmer and freezer was cool. So I thought the air circulation is not working. Cool air from freezer is not going to fresh food section. Also I saw freezer fan not rotating.
I opened the freezer back panel to check the fan. I saw the evaporator coil was clean with no frost. I closed the panel and set temperature to 5 (coldest). Next day I saw things started cooling and the fan in the freezer throwing air. Air circulation was normal.
The cooling lasted two days and again fresh food section was warm. I opened the back panel again thinking that defrost is not happening. But again I saw evaporator coil is clean with some frost. So I used air dryer and set cool air on the coil. Also I set temp to 5 (coldest).
Now I do not see anything cooling also the fan is not rotating.
Please let me know what could be the issue.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-11-2008, 11:58 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
replace your fan evaporator motor and you should be good to go.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-11-2008, 12:07 PM
MGL MGL is offline
Junior Member
Default
But the first time fan started working.
  #4 (permalink)
Old 09-11-2008, 12:20 PM
Senior Expert
APP Volunteer
Default
Sometimes they are sparatic then just quit. check the wire connects first though.
__________________
  #5 (permalink)
Old 09-11-2008, 12:29 PM
MGL MGL is offline
Junior Member
Default
I just checked the freezer now and its not cooling.
So will changing the fan motor help ?
  #6 (permalink)
Old 09-11-2008, 12:38 PM
MGL MGL is offline
Junior Member
Default
Please help.
  #7 (permalink)
Old 09-11-2008, 01:10 PM
MGL MGL is offline
Junior Member
Default
  #8 (permalink)
Old 09-11-2008, 02:14 PM
Senior Expert
APP Volunteer
Default
Feel your compressor to see if it's very hot and running.
Nat
__________________
  #9 (permalink)
Old 09-11-2008, 10:57 PM
MGL MGL is offline
Junior Member
Default
Nat,
Yes. Compressor was somewhat hot but not running.
Later I manually moved the defrost timer to start cooling cycle. After doing this the compressor started running and Freezer started cooling. But the freezer fan did not start at all.
So I think I need to change the fan motor. Also should I replace the defrost timer since freezer stops cooling and does not go to cooling cycle ?
  #10 (permalink)
Old 09-12-2008, 07:51 AM
Senior Expert
APP Volunteer
Default
The defrost timer may be "stuck" not allowing the comprssor to kick back on.
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not cooling sanjivkhanna Refrigerator & Freezer Repair 0 08-04-2008 11:55 AM
GE Refrigerator Not Cooling mjsweetm Refrigerator & Freezer Repair 1 06-24-2008 08:43 AM
GE Refrigerator not cooling gt2303a Refrigerator & Freezer Repair 0 03-07-2008 02:48 PM
GE refrigerator not cooling mlafoy Refrigerator & Freezer Repair 0 02-24-2008 01:35 PM
Refrigerator not cooling rgarippa Refrigerator & Freezer Repair 3 10-18-2007 08:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
