Discuss
icemaker
 in
Refrigerator & Freezer Repair
No water to ice maker. I replaced the water value part number 4389177 and it still does not work. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icemaker
  #1 (permalink)
Old 08-25-2010, 07:30 AM
Junior Member
rmosser is on a distinguished road
Default icemaker
Model Number: 106.56676501   Brand: Kenmore   Age: 1 - 5 years
No water to ice maker. I replaced the water value part number 4389177 and it still does not work. I tested the value with an ohm meter and it read 173 for the ice maker and 230 for the water. The water works. I read that the ohm readings should be over 200. THe value was received loose in a box with no packing material to hold it from bouncing around.
Related Models
Hoover 1060
Kenmore 1060359089 AIR CONDITIONER
Kenmore 10605 GRILL
Kenmore 106106-8130600 REFRIGERATOR
Kenmore 106106-8130610 REFRIGERATOR
Kenmore 106106-8130620 REFRIGERATOR
Kenmore 106106-8130630 REFRIGERATOR
Kenmore 106106-8130640 REFRIGERATOR
Kenmore 106106-8130650 REFRIGERATOR
Kenmore 106106-8130660 REFRIGERATOR
Kenmore 106106-8130680 REFRIGERATOR
Kenmore 106106-8130690 REFRIGERATOR
Kenmore 1061105299 ICEMAKER KIT
Kenmore 1061118553 ICEMAKER
Kenmore 1061118555 ICE MAKER
Craftsman 106161050 SEARS PAINT-TANK
Craftsman 106161051 PAINT TANK
Craftsman 106161430 SEARS PAINT TANK
Craftsman 106161450 SEARS PAINT-TANK
Craftsman 106170121 TANK TYPE COMPRESSOR
Craftsman 106170340 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106170341 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106170570 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106171141 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106171190 SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106172440 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 106172441 SEARS SINGLE CYLINDER TANK TYPE COMPRESSOR
Craftsman 1061895 CRAFTSMAN PAINT TANK
Craftsman 10618951 CRAFTSMAN PAINT TANK
Hoover 1062
Kenmore 1062155184 ICEMAKER
Kenmore 106257 WIDE WINDOW KITS
Kenmore 10629 OUTDOOR GRILL
Kenmore 10631400200 REFRIGERATOR
Kenmore 10631402200 REFRIGERATOR
Kenmore 10631404200 REFRIGERATOR
Kenmore 10631409200 REFRIGERATOR
Kenmore 10631410200 REFRIGERATOR
Kenmore 10631412200 REFRIGERATOR
Kenmore 10631414200 REFRIGERATOR
Kenmore 10631419200 REFRIGERATOR
Kenmore 10632242101 REFRIGERATOR
Kenmore 10632243101 REFRIGERATOR
Kenmore 10632249101 REFRIGERATOR
Kenmore 10632842010 REFRIGERATOR
Kenmore 10632852010 REFRIGERATOR
Kenmore 10632852011 REFRIGERATOR
Kenmore 10632853010 REFRIGERATOR
Kenmore 10632853011 REFRIGERATOR
Kenmore 10632862010 REFRIGERATOR
Kenmore 10632862011 REFRIGERATOR
Kenmore 10632863010 REFRIGERATOR
Kenmore 10632863011 REFRIGERATOR
Kenmore 10632872010 REFRIGERATOR
Kenmore 10632873010 REFRIGERATOR
Kenmore 10632882010 REFRIGERATOR
Kenmore 10632883010 REFRIGERATOR
Kenmore 10632889010 REFRIGERATOR
Kenmore 10632942101 REFRIGERATOR
Kenmore 10632943101 REFRIGERATOR
Kenmore 10632949101 REFRIGERATOR
Kenmore 10635705591 AIR CONDITIONER
Kenmore 10635710591 AIR CONDITIONER
Kenmore 10639420990 TOP MOUNT REFRIGERATOR
Kenmore 10639422990 TOP MOUNT REFRIGERATOR
Kenmore 10639424990 TOP MOUNT REFRIGERATOR
Kenmore 10639427990 TOP MOUNT REFRIGERATOR
Kenmore 10639430990 TOP MOUNT REFRIGERATOR
Kenmore 10639432990 TOP MOUNT REFRIGERATOR
Kenmore 10639434990 TOP MOUNT REFRIGERATOR
Kenmore 10639437990 TOP MOUNT REFRIGERATOR
Kenmore 10640212010 REFRIGERATOR
Kenmore 10640262010 REFRIGERATOR
Kenmore 10640263010 REFRIGERATOR
Kenmore 10640269010 REFRIGERATOR
Kenmore 10640562010 REFRIGERATOR
Kenmore 10640563010 REFRIGERATOR
Kenmore 10640563011 REFRIGERATOR
Kenmore 10640569010 REFRIGERATOR
Kenmore 10640569011 REFRIGERATOR
Kenmore 10641012100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641012101 REFRIGERATOR
Kenmore 10641012104 REFRIGERATOR
Kenmore 10641014100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641014101 REFRIGERATOR
Kenmore 10641014104 REFRIGERATOR
Kenmore 10641212100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641212101 REFRIGERATOR
Kenmore 10641214100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641214101 REFRIGERATOR
Kenmore 10641262800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641262801 SIDE-BY-SIDE
Kenmore 10641263800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641263801 SIDE-BY-SIDE
Kenmore 10641263802 REFRIGERATOR
Kenmore 10641264800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641264801 SIDE-BY-SIDE
Kenmore 10641269800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641269801 SIDE-BY-SIDE
Kenmore 10641512100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641512101 REFRIGERATOR
Kenmore 10641514100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641514101 REFRIGERATOR
Kenmore 10641519100 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641519101 REFRIGERATOR
Kenmore 10641522500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641523500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641524500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641529500 SIDE BY SIDE REFRIGERATOR
Kenmore 10641562800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641562801 SIDE-BY-SIDE
Kenmore 10641562802 REFRIGERATOR
Kenmore 10641563800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641563801 SIDE-BY-SIDE
Kenmore 10641563802 REFRIGERATOR
Kenmore 10641563803 REFRIGERATOR
Kenmore 10641564800 SIDE-BY-SIDE REFRIGERATOR
Kenmore 10641564801 SIDE-BY-SIDE
Kenmore 10641564802 REFRIGERATOR
Kenmore 10641569800 SIDE-BY-SIDE REFRIGERATOR
  #2 (permalink)
Old 08-25-2010, 08:53 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Your fill valve solenoids are not the likely problem,
your resistance readings are within the factory tolerances.
Did you check to see if you had a frozen fill tube to the icemaker ?
When the icemaker cycles, do you have voltage to the solenoid, from the icemaker control module ?
This is where you should start looking at this point.
If you need more assistance, drop us a line.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker stephen dudka Refrigerator & Freezer Repair 0 06-25-2010 05:15 AM
GE Icemaker bikerpro Refrigerator & Freezer Repair 0 12-18-2009 05:31 AM
Icemaker Greg09 Refrigerator & Freezer Repair 0 11-03-2009 10:27 AM
Icemaker alanburd Refrigerator & Freezer Repair 1 01-14-2009 03:52 PM
Help with icemaker detrob340 Refrigerator & Freezer Repair 0 07-07-2008 05:18 PM
