| » How to remove and replace AP3132744 door light switch? |
Model Number: TX21R2W Brand: Amana Age: More than 10 years
I am trying to replace "Switch, door Part Number: AP3132744" in my Amana TX21R2W refrigerator.
I checked your online diagram, ordered/received the part and searched the forums for tips but they don't solve my specific problem. I can see the release tab on the new switch but I can't find a way to release the bad switch "externally" with a screwdriver/butter knife, or, "internally" by removing the control panel (2 front screws) and gently prying the front panel down a half inch to get a screwdriver in there to press the release tab. I can't see over the control panel "lip" in front of the switch and I'm afraid I'll break something inside by blindly fishing. I would appreciate any specific direction/advice on how to remove the old switch. Ads By Google Related Models |
Try to completely remove the control housing. There suppose to be 2 more screws on the back of it.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Resolved: See [Solved - Switch removal Tab release]
I don't see any other screws to remove and the Panel resists probes for release. It seems like this is more difficult to release and remove safely. I can only partially pull half of the front panel down. I think the control sliders may break if I don't find a way to release the panel all the way around. Any specific further advisement would be appreciated. Thanks for your help... Last edited by bkfnj : 08-25-2010 at 02:04 PM. Reason: Resolved |
Quote:
Pried the left side (opposite the Tab side) of the door switch down about 3/8" so I could use a Dremel with a thin flat 15/16" cutting wheel to cut a 1/8"H x 1/4"D front to back slot just above the entire left switch lip. Then I was able to coax/slide the switch body left (into the cut left slot) enough to expose and release the Tab. From there, It was simple to pull the switch and the 2 wire cable down enough to unplug the bad switch, plug in (new terminals about 1/8" wider apart - but fit) the new switch and push/snap it into the control panel to complete the successful repair.. Last edited by bkfnj : 08-25-2010 at 02:20 PM. |
I'm glad you were able to fix it. Thank you for the feed back.
__________________
| Display Modes | |
| How do I remove the push button oven light switch? | audiacommike | Oven Repair (including Ranges and Cooktops) | 1 | 02-10-2010 03:52 PM |
| How to remove freezer light switch | blumunky | Refrigerator & Freezer Repair | 1 | 05-28-2008 10:21 PM |
| Replace door light switch GE Mongram refrigerator | daespe | Refrigerator & Freezer Repair | 4 | 03-02-2008 02:06 PM |
| How to remove Control Panel to replace switch | dan0409 | Dishwasher Repair | 0 | 02-08-2008 03:29 PM |
| Water leaking under door...need to know how to remove door & replace seal | edbolliera | Dishwasher Repair | 1 | 11-27-2007 03:42 AM |
