Discuss
Fridge Catch Tray Not Evaporating
 in
Refrigerator & Freezer Repair
Hi, i have a problem with a fridge that is overflowing from the catch tray. The fridge is a relative
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge Catch Tray Not Evaporating
  #1 (permalink)
Old 08-24-2010, 01:28 PM
Junior Member
Qubit is on a distinguished road
Default Fridge Catch Tray Not Evaporating
Brand: -brand-   Age: 1 - 5 years
i have a problem with a fridge that is overflowing from the catch tray. The fridge is a relative unknown make - Haier. It doesnt have a freezer section. The drain plug is not blocked and seems to be draining to the tray OK. However the tray is not evaporating.
My kitchen is not humid so evaporation should be taking place. The inside of the fridge is also wetter than i think it should be. I can only surmise something is amiss, but i dont know what?
  #2 (permalink)
Old 08-25-2010, 04:42 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Check that the condenser fan under the unit is running.
If it has one.
Also check that the vents under the unit are clean.
If your drip tray sits over some condenser coils make sure they are clean.
For the interior moisture check that the door seal is clean and sealing properly all the way around the door.
On the hinge side sometimes the seal catches on the frame, to solve this give it a light coat of white lithium grease or vaseline.
It could be that the unit is creating so much moisture that the drip tray cannot keep up.
You may want to check the interior temperature, perhaps it is too cold and is generating too much condensation. It should be 40 degrees F.
Note: Some units have an energy save switch if your unit has this turn it off.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Accumulation under Deli Tray at Bottom in Fridge Section bhavinjo Refrigerator & Freezer Repair 4 07-26-2010 10:04 AM
catch pan overflows slickford Refrigerator & Freezer Repair 1 05-03-2009 08:53 PM
Water in drain pan not evaporating lisiepug Refrigerator & Freezer Repair 5 04-21-2008 11:14 AM
