I have a Whirlpool side-by-side model ED5FHEXMQ10 and the valve assembly is part #2188746. The valve is opening and closing ok (electronically) but there is a VERY SLOW drip coming out of the water dispenser. I hate to spend 50-60 bucks on a new valve set... Is there any way to tighten it?? Looks like there are some plastic pins on the "top" of the solenoid that go into a metal tab. Can it be rotated maybe?
Thanks Steve Branson, MO
