Discuss
Amana Icemaker drip makes block of ice
 in
Refrigerator & Freezer Repair
My icemaker works fine, but water appears to be dripping from the inlet tube even after the cycle is complete.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Icemaker drip makes block of ice
  #1 (permalink)
Old 09-08-2008, 04:58 PM
Junior Member
tkhayes is on a distinguished road
Default Amana Icemaker drip makes block of ice
Model Number: SQD25VL   Brand: Amana   Age: More than 10 years
The corner of the ice bucket where the inlet tube becomes one large block of ice, with all the ice cubes frozen together and sometimes then is frozen into the spiral hook at the bottom.
I have replaced the electric water valve at the back/bottom of the fridge, I assumed that it must be leaking and water is being let in. I do not see a drip per se, but I do sometimes see a small icicle from the inlet tube.
Is there another valve somewhere that controls this? Not sure what to look for next.
Or is it letting too much water in when a cycle starts, and the excess overflows into the tray, causing a block of ice to form?
thanks
Ads By Google
Related Models
Amana SQD25VL Ref - SXS/I&W
Amana SQD25VW Ref - SXS/I&W
Amana SQD26VE Ref - SXS/I&W
Amana SQD26VL Ref - SXS/I&W
Amana SQD26VW Ref - SXS/I&W
Amana SR-19 Ref - SXS/I&W
Amana SR-522E Ref - SXS/I&W
Amana SR-522E-A Ref - SXS/I&W
Amana SR-522E-C Ref - SXS/I&W
Amana SR-522E-G Ref - SXS/I&W
Amana SR-522E-L Ref - SXS/I&W
Amana SR17A Ref - SXS/I&W
Amana SR17A-A Ref - SXS/I&W
Amana SR17A-AG Ref - SXS/I&W
Amana SR17A-C Ref - SXS/I&W
Amana SR17F Ref - SXS/I&W
Amana SR17G Ref - SXS/I&W
Amana SR17G-1 Ref - SXS/I&W
Amana SR17G-1-A Ref - SXS/I&W
Amana SR17G-1-AG Ref - SXS/I&W
Amana SR17G-1-C Ref - SXS/I&W
Amana SR17N Ref - SXS/I&W
Amana SR17N-A Ref - SXS/I&W
Amana SR17N-AG Ref - SXS/I&W
Amana SR17N-C Ref - SXS/I&W
Amana SR17W Ref - SXS/I&W
Amana SR17W-A Ref - SXS/I&W
Amana SR17W-AG Ref - SXS/I&W
Amana SR17W-C Ref - SXS/I&W
Amana SR17W-L Ref - SXS/I&W
Amana SR19A Ref - SXS/I&W
Amana SR19A-A Ref - SXS/I&W
Amana SR19A-AG Ref - SXS/I&W
Amana SR19A-C Ref - SXS/I&W
Amana SR19B Ref - SXS/I&W
Amana SR19B-A Ref - SXS/I&W
Amana SR19B-C Ref - SXS/I&W
Amana SR19B-G Ref - SXS/I&W
Amana SR19B-L Ref - SXS/I&W
Amana SR19C Ref - SXS/I&W
Amana SR19C-A Ref - SXS/I&W
Amana SR19C-C Ref - SXS/I&W
Amana SR19C-G Ref - SXS/I&W
Amana SR19C-L Ref - SXS/I&W
Amana SR19D Ref - SXS/I&W
Amana SR19E Ref - SXS/I&W
Amana SR19E-1 Ref - SXS/I&W
Amana SR19E-1-A Ref - SXS/I&W
Amana SR19E-1-C Ref - SXS/I&W
Amana SR19E-1-G Ref - SXS/I&W
  #2 (permalink)
Old 09-08-2008, 07:33 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
There are several possiblities on that, but I would start by checking to see if the ice tray is over filling or if the water isn't going into the tray properly.
nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-09-2008, 05:15 AM
Junior Member
Default
I watched it cycle just now. The plastic fingers pushed some ice cubes out, and I heard the water come on. I could stick my fingers in the ice tray, but I cannot see it from the front. Water did not 'overflow' I do not think, but after the water shut off, you can see a small steady drip from under the fill hose corner of the tray.
the drip is one drop every few seconds.
The fill hose is flexible, so I pulled it out of its location and it does not appear to drip from there, but still drips from the right corner of the ice maker mechanism. Would the icemaker tray be made of plastic and perhaps cracked, so the leak is there?
Sounds like I might have to take it all out, but I am not really looking forward to that.
  #4 (permalink)
Old 09-09-2008, 05:25 AM
Junior Member
Default
I think I see it now - there appears to be a seam in the icemaker where it holds the water and makes the cubes. When I look underneath the mechanism, I see a drip forming at the corner.
It looks like the part that holds the water is several parts with a plastic or rubbery seal and it is leaking there.
I assume then this is a replacement AP178365 part to replace the whole thing?
  #5 (permalink)
Old 09-09-2008, 07:20 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default Tweak the amount of water comes into the mold
On the right hand side midways is a tiny adjustment screw.
Turn it counter clockwize a hair and tweak the water level. Idealy it should be 7.5 seconds. but if the mold is not level then it may slightly drip.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker makes ice and melts away jansimply Refrigerator & Freezer Repair 5 04-02-2010 06:18 AM
GE Icemaker makes ice but doesnt dump cabledog52 Refrigerator & Freezer Repair 0 10-28-2009 08:22 AM
new icemaker but only makes a few ice cubes radman641 Refrigerator & Freezer Repair 1 04-16-2009 04:12 PM
Water is overflowing the icemaker and freezing into ice collector, makes ice block boblaw213 Refrigerator & Freezer Repair 0 07-29-2008 09:13 AM
