Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   cooling problem (http://forum.appliancepartspros.com/refrigerator-freezer-repair/117556-cooling-problem.html)
Jeffer 08-23-2010 11:12 AM
cooling problem
Stopped cooling, I upluged it for 24 hours then I pluged it back in worked fine for a few days then stopped cooling again. was told it could be a defrost timer. I looked up parts diagram online did not see a defrost timer listed. there was 2 different defrost therastats. could one of these be the problem.
Gene 08-23-2010 01:24 PM
Have you seen a frost build up on the rear panel inside the freezer?
Does the fan inside the freezer work properly?
Here are the breakdown diagrams and Replacement parts for General Electric GTS22ICMBRWW Refrigerator | AppliancePartsPros.com
Jeffer 08-23-2010 03:50 PM
NO Frost , Everything else works Great. it acts like when it go in to a defrost cycle it gets hung up.
Gene 08-23-2010 07:20 PM
There is no defrost timer in your refrigerator. Everything (including the defrost cycle) is operated by the main control board which probably is the culprit.
- The main control board Part number: AP4436216
Jeffer 08-24-2010 07:34 AM
Thank You for your help! Have a Blessed Day.
Gene 08-24-2010 02:21 PM
