Discuss
Access/check defrost timer
 in
Refrigerator & Freezer Repair
How do I access defrost timer to check it ... I don't want to break the plastic parts .. the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Access/check defrost timer
  #1 (permalink)
Old 08-19-2010, 11:33 AM
Junior Member
fad60 is on a distinguished road
Default Access/check defrost timer
Model Number: arb220zcw   Brand: Amana   Age: 5 - 10 years
How do I access defrost timer to check it ... I don't want to break the plastic parts .. the on line blow up is not detailed enough? Also where on the diagrams is the defrost Thermostat on plate 4 / number 30?
Related Models
Amana ARB220ZCW REF - BOTTOM MOUNTS
Amana ARB2214CB REF - BOTTOM MOUNTS
Amana ARB2214CC REF - BOTTOM MOUNTS
Amana ARB2214CSL REF - BOTTOM MOUNTS
Amana ARB2214CSR REF - BOTTOM MOUNTS
Amana ARB2214CW REF - BOTTOM MOUNTS
Amana ARB2217CB REF - BOTTOM MOUNTS
Amana ARB2217CC REF - BOTTOM MOUNTS
Amana ARB2217CSL REF - BOTTOM MOUNTS
Amana ARB2217CSR REF - BOTTOM MOUNTS
Amana ARB2217CW REF - BOTTOM MOUNTS
Amana ARB224RCB REF - BOTTOM MOUNTS
Amana ARB224RCC REF - BOTTOM MOUNTS
Amana ARB224RCW REF - BOTTOM MOUNTS
Amana ARB2257CB REF - BOTTOM MOUNTS
Amana ARB2257CC REF - BOTTOM MOUNTS
Amana ARB2257CSL REF - BOTTOM MOUNTS
Amana ARB2257CSR REF - BOTTOM MOUNTS
Amana ARB2257CW REF - BOTTOM MOUNTS
Amana ARB2259CB REF - BOTTOM MOUNTS
Amana ARB2259CC REF - BOTTOM MOUNTS
Amana ARB2259CS REF - BOTTOM MOUNTS
Amana ARB2259CW REF - BOTTOM MOUNTS
Amana ARB2517CB REF - BOTTOM MOUNTS
Amana ARB2517CC REF - BOTTOM MOUNTS
Amana ARB2517CSL REF - BOTTOM MOUNTS
Amana ARB2517CSR REF - BOTTOM MOUNTS
Amana ARB2517CW REF - BOTTOM MOUNTS
Amana ARB2557CB REF - BOTTOM MOUNTS
Amana ARB2557CC REF - BOTTOM MOUNTS
Amana ARB2557CSL REF - BOTTOM MOUNTS
Amana ARB2557CSR REF - BOTTOM MOUNTS
Amana ARB2557CW REF - BOTTOM MOUNTS
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
Amana ARE640 RANGE- S/C S/I DDRAFT GAS
Amana ARE640 RANGE- S/C S/I DDRAFT ELE
Amana ARE650 RANGE- S/C S/I DDRAFT GAS
Amana ARE650 RANGE- S/C S/I DDRAFT ELE
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 08-19-2010, 12:57 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
The defrost timer is located in the roof panel of the fresh food compartment,You can remove the clear plastic light lens cover and access the defrost timer notched timer dial and advance it to any part of the cycle you wish.
If you wish to access the timer body itself , you will need to carefully remove the complete panel and access the timer from the inside of the panel.
Your defrost thermostat is located on the evaporator,
That is located, behind the back wall of the freezer compartment.
You will need to empty the freezer of everything and remove the back wall,
You will find the thermostat clipped to the right, top side of the evaporator assembly.
I have attached the service manual for a better explanation for you.
(concentrate on pages 30 through 35, that will answer both your questions for accessing the parts you wish to test).
http://servicematters.com/maytag_lib...16021484R1.pdf
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-19-2010, 05:23 PM
Junior Member
Default
To Joe M. Thanks A Bunch .. I'll Let You Know How The Items Test Out-you Guys Are The Best!!!
  #4 (permalink)
Old 08-19-2010, 10:05 PM
Junior Member
Default
I'm sorry but is it possible that my AMANA ARB220ZCW doesn't have a screw #20 plate #3 to remove the bulb cover because I cannot find one to remove ... how big is this screw supposed to be?
  #5 (permalink)
Old 08-20-2010, 07:55 AM
Senior Expert
Default
It's a pretty small screw,
If you look at the far end of the lens cover(#3) you should see an indentation in the center of the cover, the screw will be located inside of the indentation.
Once you remove the screw you pull down slightly on the end and use the "divots" on the front of the cover and push away from you to unlatch the lens cover.
Has someone worked on this unit before ?
They may have forgot to put the screw back in ?
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 08-20-2010, 11:55 AM
Junior Member
Default
I Removed The Light Shield By Just Pulling Down And Back ... There Was No Screw Though No One Worked On This Frig Ever ... I Can Only Assume The Dealer Checked It Out Before Delivery 7 Years Ago And Never Replaced The Screw!
Thanks A Lot Joe
  #7 (permalink)
Old 08-20-2010, 11:58 AM
Senior Expert
Default
Thanks A Lot Joe
You are quite welcome.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost problem, can't find the timer to check apcf Refrigerator & Freezer Repair 3 01-22-2010 05:14 PM
How to access defrost timer in Top Freezer Maytag? BudBackEast Refrigerator & Freezer Repair 4 10-23-2009 06:53 PM
defrost timer access john17 Refrigerator & Freezer Repair 0 06-21-2009 12:16 PM
Getting access to defrost timer david_navigator Refrigerator & Freezer Repair 4 12-24-2008 01:39 AM
How do I check the defrost timer, heater, and thermostat and repair whats wrong elgem3 Refrigerator & Freezer Repair 1 10-26-2008 04:36 PM
