My Amana side by side has little plastic inserts in the bottom hinges of both doors. They both opened and closed silently for lo these many years. Then the fridge door hinge insert broke so I ordered a new set up took out theold ones put the shims and new plastic shims in and reinstalled the hinge now it squeaks and groans like crazy, i just finished this job ten minutes ago, it is annoying and sounds like the new one is just going to break. I tried making sure the metal hinge part was perfectly straight up and down et, still squeaks like cray. Thoughts?
