I have a White-Westinghouse model #WWSS2601KS3 and the water line from the water valve to the water filter has come off and is leaking water everytime the water valve releases water. When you get water from the door the water is pushed out of the valve with the water pressure from the house water outlet.
How can I fix this problem?:(
