I have been having this problem for a while. It has gotten to the point where I can't keep anything in the freezer because it will get so warm that the ice melts and everything else defrosts but then it will start working again and then everything freezes. I started noticing it when icecicles started forming from the ice maker. If anyone else has had this or knows how to fix it I would greatly appreciate it. Also does anyone know if there is still a manufacture's warenty.
Thanks everyone
I forgot to add that the fridge side works perfect. Originally Posted by: rjensen I have been having this problem for a while. It has gotten to the point where I can't keep anything in the freezer because it will get so warm that the ice melts and everything else defrosts but then it will start working again and then everything freezes. I started noticing it when icecicles started forming from the ice maker. If anyone else has had this or knows how to fix it I would greatly appreciate it. Also does anyone know if there is still a manufacture's warenty.
Thanks everyone
