My freezer working fine, fridge is not cold. took off back in freezer and it seems the fan isnt blowing any air into the fridge. would it be just the fan to replace or could it be something else?
freezer working fridge isn't cold. if the fan isn't running do I need a new fan or could it be another problem?
Here is your wiring diagram. http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202225759.pdfAs you can see the evaporator fan and compressor and condenser fan are all in parallel so if the other 2 work then odds are high that the evaporator fan is shot. This can be checked by measuring the voltage across the fan. Also check that you do not have a defrost problem that is so bad it is jamming the fan. |
THIS FORUM IS DEAD!!!!!!! |
Thanks! Does fan normaly run at all times or does go on and off? Also is it easy to replace?
[COLOR="Blue"]Does fan normaly run at all times or does go on and off?[/COLOR] Only runs when the compressor runs.
[COLOR="Blue"]Also is it easy to replace?[/COLOR] Usually they are not hard to replace. |
