Discuss
Gurgling noise when shutting refer door
 in
Refrigerator & Freezer Repair
Greetings! We have a 4 year old sub zero 632 side-by-side refer. When we open the refer door to retrieve
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Gurgling noise when shutting refer door
  #1 (permalink)
Old 08-30-2008, 08:53 AM
mjr mjr is offline
Junior Member
mjr is on a distinguished road
Default Gurgling noise when shutting refer door
Model Number: 632   Brand: Sub Zero   Age: 1 - 5 years
Greetings!
We have a 4 year old sub zero 632 side-by-side refer. When we open the refer door to retrieve an item then shut the door there is a gurgling sound from the unit for approx. 3 to 5 seconds. A short term solution has been to empty an accumulation of water from the built in water tray under the the unit. This seams to take care of the problem for about a week but then the sound and water return. Can anyone please let us know how to permanently solve this issue?
Thanks!
Ads By Google
Related Models
Amana 632-3J Room Air Conditioner
Hoover 634 Frigidaire/refrigerator
Hoover 64 Frigidaire/electric Range
Maytag 640C Dryer - Gas
Maytag 640W Dryer - Gas
Magic Chef 6458XRA Range - S/c S/i Gas
Magic Chef 6458XRL
Magic Chef 6458XRS Range - S/c S/i Gas
Magic Chef 6458XRW Range - S/c S/i Gas
Magic Chef 6458XTA Range - S/c S/i Gas
Magic Chef 6458XTS Range - S/c S/i Gas
Magic Chef 6458XTW Range - S/c S/i Gas
Magic Chef 6498VRA Range - S/c S/i Gas
Magic Chef 6498VRV Range - S/c S/i Gas
Magic Chef 6498VTA Range - S/c S/i Gas
Magic Chef 6498VTV Range - S/c S/i Gas
Magic Chef 6498VVA
Magic Chef 6498VVD Range - S/c S/i Gas
Magic Chef 6498VVV Range - S/c S/i Gas
Magic Chef 6498XRA Range - S/c S/i Gas
Magic Chef 6498XRS Range - S/c S/i Gas
Magic Chef 6498XRW Range - S/c S/i Gas
Magic Chef 6498XTA Range - S/c S/i Gas
Magic Chef 6498XTS Range - S/c S/i Gas
Magic Chef 6498XTW Range - S/c S/i Gas
Magic Chef 6498XVA
Magic Chef 6498XVB Range - S/c S/i Gas
Magic Chef 6498XVS Range - S/c S/i Gas
Magic Chef 64EA-3CKW Range - S/c S/i Gas
Magic Chef 64EB-3CKW Range - S/c S/i Gas
Magic Chef 64EN-3CKW Range - S/c S/i Gas
Magic Chef 64EY-3CKW Range - S/c S/i Gas
Magic Chef 64F
Magic Chef 64F*-3CKXW
Magic Chef 64FA-3CKVW Range - S/c S/i Gas
Magic Chef 64FA-3CKW Range - S/c S/i Gas
Magic Chef 64FA-3CKX Range - S/c S/i Gas
Magic Chef 64FA-3CKXW Range - S/c S/i Gas
Magic Chef 64FB-3CKW Range - S/c S/i Gas
Magic Chef 64FK-3CKX Range - S/c S/i Gas
Magic Chef 64FK-3CKXW Range - S/c S/i Gas
Magic Chef 64FN-3CKVW Range - S/c S/i Gas
Magic Chef 64FN-3CKW Range - S/c S/i Gas
Magic Chef 64FN-3CKX Range - S/c S/i Gas
Magic Chef 64FN-3CKXW Range - S/c S/i Gas
Magic Chef 64FY-3CKW Range - S/c S/i Gas
Magic Chef 64FY-3CKX Range - S/c S/i Gas
Magic Chef 64FY-3CKXW Range - S/c S/i Gas
Magic Chef 64H-4TKVW Range - S/c S/i Gas
Magic Chef 64H-4TKXW Range - S/c S/i Gas
Magic Chef 64HA-4TKVW Range - S/c S/i Gas
Magic Chef 64HA-4TKXW Range - S/c S/i Gas
Magic Chef 64HK-4TKXW Range - S/c S/i Gas
Magic Chef 64HN-4TKVW Range - S/c S/i Gas
Magic Chef 64HN-4TKXW Range - S/c S/i Gas
Hoover 65
Amana 650.000 Mwave - Family Size (60 Hz)
Amana 650.001 Range - S/c S/i Ddraft Gas
Magic Chef 6500PRA Range - S/i Std Ele
Magic Chef 6500PRL
Magic Chef 6500PRS
Magic Chef 6500PRW Range - S/i Std Ele
Magic Chef 6500SRS Range - S/i Std Ele
Hoover 651 Frigidaire/electric Range
Amana 651.000 Range - S/c S/i Ddraft Gas
Amana 651.001 Range - S/c S/i Ddraft Gas
Amana 651.002 Range - S/c S/i Ddraft Gas
Amana 651.003 Range - S/c S/i Ddraft Gas
Amana 651.004 Range - S/c S/i Ddraft Gas
Amana 651.006 Range - S/c S/i Ddraft Gas
Kenmore 651.89918100  WRINGER WASHER
Admiral 651AH Range - S/c F/s Ele
Admiral 651WH Range - S/c F/s Ele
Admiral 653AH-HV Range - F/s Std Ele
Admiral 653AH-V Range - F/s Std Ele
Admiral 653AJ-HV Range - F/s Std Ele
Admiral 653AJ-V Range - S/c F/s Ele
Admiral 653AJ-V-CX Range - F/s Std Ele
Admiral 653WH-HV Range - F/s Std Ele
Admiral 653WH-V Range - F/s Std Ele
Admiral 653WJ-HV Range - F/s Std Ele
Admiral 653WJ-V Range - S/c F/s Ele
Admiral 653WJ-V-CX Range - F/s Std Ele
Admiral 654AD-HVW Range - F/s Std Ele
Admiral 654AG-HVW Range - F/s Std Ele
Admiral 654AH-ELVW Range - F/s Cont Clean Ele
Admiral 654AH-EVW Range - F/s Std Ele
Admiral 654AH-EW Range - F/s Std Ele
Admiral 654HG-HVW
Admiral 654WD-HVW Range - F/s Std Ele
Admiral 654WG-HVW Range - F/s Std Ele
Admiral 654WH-ELVW Range - F/s Cont Clean Ele
Admiral 654WH-ELW Range - F/s Cont Clean Ele
Admiral 654WH-EW Range - F/s Std Ele
Magic Chef 6551WRA Range - S/i Std Ele
Magic Chef 6551WRW Range - S/i Std Ele
Magic Chef 6551WUA Range - S/i Std Ele
Magic Chef 6551WUB Range - S/i Std Ele
Magic Chef 6551WUW Range - S/i Std Ele
Magic Chef 6551XRA Range - S/i Std Ele
Magic Chef 6551XRL
Magic Chef 6551XRS
Magic Chef 6551XRW Range - S/i Std Ele
Magic Chef 6551XUA Range - S/i Std Ele
Magic Chef 6551XUB Range - S/i Std Ele
Magic Chef 6551XUW Range - S/i Std Ele
Admiral 655AH-CVW Range - F/s Std Ele
Admiral 655WH-CVW Range - F/s Std Ele
Admiral 656AH-EHVW Range - F/s Std Ele
Admiral 656HH-EHVW Range - F/s Std Ele
Admiral 656WH-EHVW Range - F/s Std Ele
Maytag 65C Dryer - Gas
Magic Chef 65HA-1 Range - S/i Std Ele
Magic Chef 65HA-3W Range - S/i Std Ele
Magic Chef 65HA-3X Range - S/i Std Ele
Magic Chef 65HN-1 Range - S/i Std Ele
Magic Chef 65HN-3W Range - S/i Std Ele
Magic Chef 65HN-3X Range - S/i Std Ele
Hoover 66
  #2 (permalink)
Old 08-31-2008, 12:47 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Not to familiar with the sub zero, but your drain tube should have a bend in it. If you cut the tube so it is a straight shot to the drain pan, this will get rid of the gurgling sound. Just be sure the tube will drain the water into the pan if you decide to cut it, or you'll have a mess to clean up once a day
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clicking noise from fresh food side of refer upstaterv Refrigerator & Freezer Repair 0 01-25-2010 07:52 AM
Door noise tjwaller Dishwasher Repair 1 01-17-2010 01:02 AM
refer noise okiore Refrigerator & Freezer Repair 1 01-15-2010 07:02 PM
Poping noise when door opens Joe Jr Refrigerator & Freezer Repair 3 08-10-2009 12:35 PM
Dishwasher gurgling and not filling with water fixitplease Dishwasher Repair 1 10-24-2008 03:37 PM
