My circuit board on the freezer door was burned up. I replaced the circuit board and various parts that go into the fountain assembly, but now the icemaker is not recieving water. If I switch the solenoid in the back of the fridge with the fridge water solenoid and push the fridge water button, then water goes up into the ice maker, but it will not do it on its own, even though the arm is down. If you could please help me with the part that makes the water go into the icemaker, it would be greatly appreciated. Thank you.
Sincerely, Veksauto
