MATT1946
#1 Posted : Friday, August 13, 2010 5:38:45 AM(UTC)
MATT1946
Water On Floor Hear It Running Doesn't Get Cold
#2 Posted : Friday, August 13, 2010 6:06:33 AM(UTC)
Here are the parts
Replacement parts for FRIGIDAIRE LFFU1765DW3 Frigidaire/freezer | AppliancePartsPros.com
Water could be from the frost in the unit, it has overflowed the drain cup.
Also the compressor line running in the drain cup helps with evaporation of the water so if the compressor is not cooling this line never gets warm.
Double check that the compressor is running, it should be warm and you should be able to feel it vibrating.
If yes
Check to be sure that the evaporator fan is running.
Remove the cover so you can see the evaporator coils.
If there is no frost on the coils your sealed system is toast.
If there is just frost in one area (usually where the freon enters the coils) or it is blotchy then you are likely low on freon.
Of coarse the above is also dependent on how long it has been since a defrost cycle.
Either of the above is an expensive repair and it is probably better to put those dollars toward a new unit.
Samsung Fridge and freezer incorrect temps (Refrigerator & Freezer Repair)
by Guest 4/3/2024 9:24:02 AM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Freezer temperature varying (Refrigerator & Freezer Repair)
by Guest 4/2/2024 6:15:22 AM(UTC)
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Intermittent fridge/freezer (Refrigerator & Freezer Repair)
by Hystiker 2/21/2024 4:01:30 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
