freezer defrosted refrigerater side isnt getting cold
Here are your parts Replacement parts for MAYTAG MSD2651HEW Ref - SXS/I&W | AppliancePartsPros.comNot sure if I understand your post. If you mean that the evaporator coils in the freezer section are not iced up and the freezer temperature is good, then I would check the damper (Item 8 in Section 7). It should be open. Also check that the evaporator fan is running. It is required to push cold air into the fresh food section. Also that Item 19 in Section 11 is not blocked by a food items. I believe this is an air return grill between the two sections. |
THIS FORUM IS DEAD!!!!!!! |
