| » fan with no ground/neutral |
Model Number: rb215lash Brand: Samsung Age: 1 - 5 years
well Hello all,,,hoping someone could help,,,i have two problems,,,one is the icemaker is filling up with water and turning into a block of ice,,,not good. i changed the solenoid about a year ago and it was fine.on another thread someone replaced some circuit board and the icemaker assy and it solved their problem,,,me,,, i need help. The other problem i have is the fan inside the freezer,it will not work,i put a new fan in and it still did not work. I tested the fan at a 110 vac outlet and it worked.i tested the connector in the back of the unit and found only the hot leg works,,,no neutral.if i run a jumper for a neutral to refrigerator ground fan works fine,,,,soooo HELP,,,i need lots of help Read more: water overfilling/fan losing ground http://forum.appliancepartspros.com Ads By Google Related Models |
Quote:
Just make sure, the new connections are water proof,and insulated. Now for the icemaker, I believe this unit has a "twist tray" icemaker ? If so, make sure the twist tab(s) on the back of the tray and the "catch" tab on the icemaker housing are not broken off, and that the tray does no move too far forward. Hopefully it's that minor.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Quote:
Remember, you'll need to replace that in line filter (1) once a year, wether it needs it, or not. As for the twist tray, I mentioned that as your first check / repair, I've seen a lot of guys throw all kinds of parts at this style ice maker, only to find out it was the tray catch(s) all along. You still may need a control module or sensor, but check the twist tray and catches first.
__________________
Quote:
Vinny, Is it working now ? What did you find and need to repair the unit ?
__________________
hi Joe, did not reply, i am very sorry, as it turned out i gave up , i put filters in and had manager call someone in to fix,,,they were not able to fix either,,ice production is at a minimal,,but that is just how its gonna be,,thanks so much for your help before and sorry again for not repling,,hard to get on line
Quote:
Sorry to hear that. The icemaker in that type unit are slower than the average "heat release" ice maker(60 minutes vs 90 minutes). I was under the impression it was taking way longer. Thanks for the response, glad you're doing well.
__________________
| Display Modes | |
| hot to neutral | anitamike1@yahoo.com | Refrigerator & Freezer Repair | 1 | 07-14-2010 03:33 PM |
| 3 speed neutral transmission | masterblaster | Washer Repair | 1 | 02-14-2010 06:58 AM |
| no neutral to blower | kurt89 | Refrigerator & Freezer Repair | 1 | 01-08-2010 11:49 PM |
| Neutral Short On Old Oven | MWEVAN | Oven Repair (including Ranges and Cooktops) | 0 | 10-19-2009 06:24 PM |
| Voltage different from neutral & Ground | Earl Dryer | Oven Repair (including Ranges and Cooktops) | 21 | 11-20-2008 05:50 PM |
