Discuss
Amana Refrigerator Freezing in Refrigerator
 in
Refrigerator & Freezer Repair
My 15 year old Amana Refrigerator is freezing in the refrigerator compartment. Have turned temp control to lowest setting. Not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Refrigerator Freezing in Refrigerator
  #1 (permalink)
Old 08-27-2008, 03:17 PM
cdodson1 cdodson1 is offline
Junior Member
cdodson1 is on a distinguished road
Default Amana Refrigerator Freezing in Refrigerator
Model Number: tzi21rw   Brand: Amana   Age: More than 10 years
My 15 year old Amana Refrigerator is freezing in the refrigerator compartment. Have turned temp control to lowest setting. Not sure if it is running all the time. Seems that when I am near it is running.
Any hints for fixing appreciated! Would like to fix myself (well...have hubby do it!) if doable.
Thank you!
Crystal
Related Models
Amana TZI21RW Ref - Top Mount
Amana TZI22R2E Ref - Top Mount
Amana TZI22R2L Ref - Top Mount
Amana TZI22R2W Ref - Top Mount
Amana TZI22R3E Ref - Top Mount
Amana TZI22R3L Ref - Top Mount
Amana TZI22R3W Ref - Top Mount
Amana TZI22RE Ref - Top Mount
Amana TZI22RL Ref - Top Mount
Amana TZI22RW Ref - Top Mount
Amana TZI22V2E Ref - Top Mount
Amana TZI22V2L Ref - Top Mount
Amana TZI22V2W Ref - Top Mount
Amana TZI23QG Ref - Top Mount
Amana TZI23QL Ref - Top Mount
Amana TZI23QW Ref - Top Mount
Hoover U
Amana U-23C Freezer - Vertical
Amana U-23C-A Freezer - Vertical
Amana U-23C-C Freezer - Vertical
Amana U-23C-G Freezer - Vertical
Hoover U1025---
Magic Chef U11GA-1 Range - F/s Std Gas
Magic Chef U11GA-1-GG Range - F/s Std Gas
Magic Chef U11GA-1K Range - F/s Std Gas
Magic Chef U11GA-2KW Range - F/s Std Gas
Magic Chef U11GA-2W Range - F/s Std Gas
Magic Chef U11GK-1 Range - F/s Std Gas
Magic Chef U11GK-1-GG Range - F/s Std Gas
Magic Chef U11GK-1K Range - F/s Std Gas
Magic Chef U11GK-2KW Range - F/s Std Gas
Magic Chef U11GK-2W Range - F/s Std Gas
Magic Chef U11GN-1 Range - F/s Std Gas
Magic Chef U11GN-1-GG Range - F/s Std Gas
Magic Chef U11GN-1K Range - F/s Std Gas
Magic Chef U11GN-2KW Range - F/s Std Gas
Magic Chef U11GN-2W Range - F/s Std Gas
Magic Chef U11GS-1 Range - F/s Std Gas
Magic Chef U11GS-1-GG Range - F/s Std Gas
Magic Chef U11GS-1K Range - F/s Std Gas
Magic Chef U11GS-2KW Range - F/s Std Gas
Magic Chef U11GS-2W Range - F/s Std Gas
Magic Chef U11GY-1 Range - F/s Std Gas
Magic Chef U11GY-1-GG Range - F/s Std Gas
Magic Chef U11GY-1K Range - F/s Std Gas
Magic Chef U11GY-2KW Range - F/s Std Gas
Magic Chef U11GY-2W Range - F/s Std Gas
Magic Chef U11HA-10 Range - F/s Std Gas
Magic Chef U11HN-10 Range - F/s Std Gas
Magic Chef U11HY-10 Range - F/s Std Gas
Magic Chef U11JA-2KW Range - F/s Std Gas
Magic Chef U11JK-2KW Range - F/s Std Gas
Magic Chef U11JN-2KW Range - F/s Std Gas
Magic Chef U11JS-2KW Range - F/s Std Gas
Magic Chef U11JY-2KW Range - F/s Std Gas
Amana U1200I Commercial Microwaves
Amana U12F Freezer - Vertical
Amana U13K Freezer - Vertical
Amana U13K-A Freezer - Vertical
Amana U13K-AG Freezer - Vertical
Amana U13K-C Freezer - Vertical
Amana U13W Freezer - Vertical
Amana U13W-A Freezer - Vertical
Amana U13W-AG Freezer - Vertical
Amana U13W-C Freezer - Vertical
Amana U15F Freezer - Vertical
Amana U1600D Commercial Microwaves
Amana U1600I Commercial Microwaves
Amana U1600S Commercial Microwaves
Amana U16K Freezer - Vertical
Amana U16K-A Freezer - Vertical
Amana U16K-AG Freezer - Vertical
Amana U16K-C Freezer - Vertical
Amana U16W Freezer - Vertical
Amana U16W-A Freezer - Vertical
Amana U16W-AG Freezer - Vertical
  #2 (permalink)
Old 08-27-2008, 03:41 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
For starters I would check the damper make sure it's closing, by your description it's probably open, if it's not closing properly then you will need either part AP4247998 or AP71843 (either one should work, but not is stock so might take a while to get. Hope that helps you some. Depending on where you live you might find one locally if you need it, part number R0161072.
Hope that helps
Nat
  #3 (permalink)
Old 08-28-2008, 12:52 PM
Junior Member
Default
Quote:
Hope that helps
Nat
Have confirmed refrigerator does shut off.
Thanks for your help! If you know anything else based on fact that fridge is shutting off, please let me know.
Crystal
  #4 (permalink)
Old 05-10-2009, 06:56 PM
Nemo Nemo is offline
Junior Member
Nemo is on a distinguished road
Default Amana TZI21RW refrigerator
We are having similar problems. Our 15-year old Amana seems to be running all the time. It is a frostless freezer yet there is frost accumulating on the back of the freezer (freezer is on top). The refrigerator is not refrigerating. We've emptied it out and are just using the freezer but it is running all the time. We've cleaned underneath and behind the appliance and defrosted. There is not change. Might it need freon?
  #5 (permalink)
Old 05-10-2009, 09:12 PM
woodchuckie woodchuckie is offline
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Part 5 diagram 5 is your defrost timer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator is freezing everything KarenC Refrigerator & Freezer Repair 0 03-11-2008 04:38 PM
Refrigerator is freezing everything compudoc Refrigerator & Freezer Repair 2 01-02-2008 03:20 AM
refrigerator freezing everything dbares1 Refrigerator & Freezer Repair 2 10-26-2007 04:09 PM
Refrigerator freezing sandy Refrigerator & Freezer Repair 1 10-17-2007 04:02 PM
Refrigerator freezing Michele Glazer Refrigerator & Freezer Repair 1 08-01-2007 10:18 PM
