The Kenmore side by side refrigerator mentioned above has a model WR30X0290 ice maker. The water fill solenoid valve gets intermittent signals to fill after the cube tray is filled, causing water to overflow. I have replaced the solenoid valve assembly. Typically after the initial fill, the solenoid cycles again and again after 30 seconds or so for a few seconds each time. What switch controls this function and can it be replaced easily.
