Discuss
Dispenser motor replacement question..
 in
Refrigerator & Freezer Repair
I have an intermittent operation of the ice dispenser. When it is not working, I have checked the switch and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Dispenser motor replacement question..
  #1 (permalink)
Old 09-17-2007, 11:30 AM
crabby crabby is offline
Junior Member
crabby is on a distinguished road
Default Dispenser motor replacement question..
Model Number: GD25DIXHW00   Brand: Whirlpool   Age: 5 - 10 years
I have an intermittent operation of the ice dispenser. When it is not working, I have checked the switch and have power going in and back out. I lubricated the unit from above without accessing it (under the ice bucket). That helped for a while, but it is inoperative again. I believe that the motor is going. I found your Part Number: AP3776020 which I beleve is correct. How can I find the breakout or directions for the right way to access this motor for changeout? (When approaching from the front panel, I could not get the housing loose, so stopped to order part and find correct instructions.) Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-18-2007, 10:26 PM
Junior Member
Default
Not much point in ordering part unless there is a way to get help or obtain this information?
  #3 (permalink)
Old 09-19-2007, 04:27 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Click on your model # above and look at the picture for airflow, this should explain everything.
__________________
  #4 (permalink)
Old 09-19-2007, 09:56 PM
Junior Member
Default
Don't mean to be contrary, but the airflow diagram seems to have nothing to do with the motor in the ice dispenser. I did click item #8 "Motor and ice container" and that is where I found the motor part number. But, it states "image not available" so no help there. The dispenser front (item #4) does not indicate if it is acccess for the motor, nor does item #5, so I cannot tell which way to access that motor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water intake valve installation question deano49 Refrigerator & Freezer Repair 3 11-01-2007 11:33 AM
Water dispenser hose replacement. trcpal Refrigerator & Freezer Repair 0 08-29-2007 08:40 PM
follow up to frigid rear drum question treefrog Washer Repair 0 08-19-2007 02:24 PM
motor replacement peppi Dryer Repair 1 08-04-2007 07:20 PM
Indoor water dispenser hose replacement JOHN BIERMAN Refrigerator & Freezer Repair 1 08-01-2007 10:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
