I have a kenmore 55522 side by side. The ice maker has stopped working. I want to know how to remove the ice maker? The left side looks like I can press up on a tab and it will slide out of the braket. I can't find a tab to press on the right side. Is there one or do I need to unscrew the bracket? Where do I unhook the power? Add a comment Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use. Comment:
Here's Why :
- Get your answer sooner
- Consult our best Experts
- Get as many Solutions as you need
- Satisfaction guaranteed
if (typeof messageRater != 'undefined') { messageRater.add_onRated(showAskAd.bind(this)); } if (typeof rate_ctl00_ctl00_MainColumn_CenterColumn_ctrl_answer_ctrl_answerRate != 'undefined') { var ctrl = rate_ctl00_ctl00_MainColumn_CenterColumn_ctrl_answer_ctrl_answerRate; if (ctrl !== null) { ctrl.observe('afterChange',removeRateMessage.bind(ctrl)); } } function removeRateMessage() { //var spnRateObj = $('< % = ctrl_pager.SpnRateClientID % >'); var spnRateObj = $('dummyID'); if (spnRateObj === null) return; spnRateObj.style.display = 'none'; }
