Just recieved the Dual Defrost heater assembly in the mail... didn't come with instructions at all. I haven't attempted to install yet... as I noticed the two different bulbs w/ brackets are separate. When I removed the original, i only had to remove one bracket that was screwed to the metal frame underneath the coils. However, i'm confused as to how these TWO brackets will attach to the same spot. Do I need to screw the brackets together first?
