anchortown
#1 Posted : Saturday, August 23, 2008 9:38:45 AM(UTC)
anchortown
The unit will run and freeze OK. The next day it thaws. What should I do?
libertyappl
#2 Posted : Saturday, August 23, 2008 10:46:49 AM(UTC)
libertyappl
Can you be a little more descriptive as to how long it runs, then starts thawing, and so forth.
Nat
anchortown
#3 Posted : Sunday, August 24, 2008 4:52:46 AM(UTC)
anchortown
Yes it will work OK for one day and then the next day it will warm and not work.
#4 Posted : Sunday, August 24, 2008 11:06:22 AM(UTC)
When it fails, try to find out what is working/not working? Any light bulbs working? Fans turning?
anchortown
#5 Posted : Monday, August 25, 2008 6:39:50 PM(UTC)
anchortown
Thanks. The inside light comes on but the fan or compressor will not run. For a while it would cool one day and then warm the next. There are two connections at the compressor. One is an overload and the other is a relay. How do I check them to see if they have power? Spent $45.00 today for tech to tell me its the compressor thats bad. He put a jumper on the controls inside the refrig and stated that it was the compressor that is bad. Told me it would cost more to replace compressor than a new refrig would cost. Even wrote up the bill saying recent storm caused low power and burned up compressor. What now?
libertyappl
#6 Posted : Monday, August 25, 2008 6:59:13 PM(UTC)
libertyappl
I've never heard of anyone "putting a jumper on the controls"
Sounds more like it's stuck in defrost with no fans running. But to check the compressor:
Get an ohm meter, set to lowest ohms and zero the meter, remove one wire at a time and label it according to the terminal on the compressor. touch one to the common (C) terminal and the other probe ti the run (M)terminal, should read between 1-10 ohms. if not the compressor is bad.
let me know and we can check something else if need be.
Nat
anchortown
#7 Posted : Tuesday, August 26, 2008 9:05:45 AM(UTC)
anchortown
Checked it as you stated. The compressor is now running and it cooled. Will wait for 24 hrs and check it again. Thanks
libertyappl
#8 Posted : Tuesday, August 26, 2008 9:11:10 AM(UTC)
libertyappl
keep us posted
anchortown
#9 Posted : Thursday, August 28, 2008 5:21:23 PM(UTC)
anchortown
Lasted being cold a few hours. Now will not run at all.
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
GE Refrigerator “dead” (Refrigerator & Freezer Repair)
by Guest 12/3/2023 8:03:32 AM(UTC)
GE french door refrigerator not dispensing water (Refrigerator & Freezer Repair)
by Guest 12/1/2023 5:51:32 AM(UTC)
GE warm refrigerator, new inverter. (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:51:12 AM(UTC)
