2 Pages12>
ec2000
#1 Posted : Saturday, August 23, 2008 5:26:53 AM(UTC)
ec2000
sounds like its running, but no cooling at all, any common things
on this model ?
libertyappl
#2 Posted : Saturday, August 23, 2008 6:45:00 AM(UTC)
libertyappl
Touch your compressor to see if it's warm or if you hear a clikcing noise near the compressor.
Nat
ec2000
#3 Posted : Saturday, August 23, 2008 12:57:18 PM(UTC)
ec2000
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
ec2000
#4 Posted : Saturday, August 23, 2008 1:00:34 PM(UTC)
ec2000
we unpluged it over nite now works,by doing that did we free up a relay
or a error in a chip allowing it to work again. watching it closely see if
happens again.
libertyappl
#5 Posted : Saturday, August 23, 2008 6:02:05 PM(UTC)
libertyappl
If it does that again repost with as much details as possible along with your complete model number
Nat
ec2000
#6 Posted : Sunday, August 24, 2008 4:25:31 AM(UTC)
ec2000
Thanks Nat
ec2000
#7 Posted : Monday, August 25, 2008 6:01:43 PM(UTC)
ec2000
model RM18F6WS Gibson small frezer bottom right side, ok once again not
cooling, i felt compresser its running very hot so i unpluged refrigerator
see if comes back on after cooling down
libertyappl
#8 Posted : Monday, August 25, 2008 6:08:30 PM(UTC)
libertyappl
Remove the back panel in the freezer and check for ice there, if you have ice look for the defrost thermostat and test whith an ohm meter for continuity, if none the replace that part. Thaw completely with hair dryer which will get you by until you can get a partin and you will have to defrost it anyway.
Nat
ec2000
#9 Posted : Tuesday, August 26, 2008 4:00:58 AM(UTC)
ec2000
thanks Nat, it came on again after being unpluged over nite ill try your
suggestion later today and let you know results Earl
ec2000
#10 Posted : Tuesday, August 26, 2008 3:50:09 PM(UTC)
ec2000
ok Nat, the refridgerator quit coolinga again this afternoon,opening the
frezer door you can see the coils are frosted over,i removed 1 screw that
cover the fan however i also removed 2 more that looks like plastic cover
in back should pull off however it wont come off, im thinking the thermostat most likely would be there. now i havent give it the big pull
trying not to break that cover. so still trying to get deeper into back of
freezer Earl
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
2 Pages12>
