| » GE side by side stopped cooling |
Model Number: GSS22WGMAWW Brand: GE Age: 1 - 5 years
Both sides stopped cooling within 2 days. Is there a defrost timer in this model?
No, your unit has a control board, located on the back. part numberAP3950129. but if you have frost or ice in the freezer -
I would remove the rear panel in the freezer to check for ice and look for the defrost element and the thermostat first (cheaper parts and you're probably going to have to defrost it anyway. You can look at a complete breakdown on this site. hope this helps Nat |
If the freezer coils are completely frosted over, you will need to unplug unit and fully defrost the coils with a hair dryer. If you have a meter, before defrosting, check the defrost thermostat for continuity while it is still cold.
If only partially frosted, you should call a pro to check refrigeration.
__________________
| Display Modes | |
| Whirpool side by side stopped cooling | donzo1 | Refrigerator & Freezer Repair | 1 | 07-30-2008 10:17 AM |
| Side by Side fridge and freezer not cooling and making no ice! | krm208 | Refrigerator & Freezer Repair | 1 | 07-11-2008 07:41 PM |
| side by side ice and water in door not cooling or freezing | Anna1441 | Refrigerator & Freezer Repair | 0 | 06-26-2008 08:11 AM |
| side by side refrigerator stopped cooling and freezing | bbcowboy | Refrigerator & Freezer Repair | 3 | 03-21-2008 07:02 PM |
| ice auger stopped working in GE side-by-side | tmouncer1 | Refrigerator & Freezer Repair | 5 | 10-24-2007 12:39 PM |
