well Hello all,,,hoping someone could help,,,i have two problems,,,one is the icemaker is filling up with water and turning into a block of ice,,,not good. i changed the solenoid about a year ago and it was fine.on another thread someone replaced some circuit board and the icemaker assy and it solved their problem,,,me,,, i need help. The other problem i have is the fan inside the freezer,it will not work,i put a new fan in and it still did not work. I tested the fan at a 110 vac outlet and it worked.i tested the connector in the back of the unit and found only the hot leg works,,,no neutral.if i run a jumper for a neutral to refrigerator ground fan works fine,,,,soooo HELP,,,i need lots of help:eek:
