Icemaker not working can someone help me.
Remove the ice maker head cover and check for 120VAC between "N" & "L" test points. Make sure the test probes are 1/2" in.
If there is 120VAC then using an insulated piece of wire (14 GA), short points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED5VHGXMQ10 Refrigerator | AppliancePartsPros.com Gene.
